Things TO do in your garage
You can't plan for every little thing that will go wrong, but you can use some common sense and a little safety equipment to keep your butt safe. We're required to wear ridiculous amounts of safety equipment on the job. I did see a girl get her toes run over by a military 2 1/2 ton truck and she was ok. Anyone who's seen one of those know they're heavy! I love my steel toe boots now.
More jack stand safety dont use the jack stands that tou find buryed in a garage with no markings on them. I put my dads 2000 power stroke on 2 and crushed them flat also buy the bigest jack stands and jacks you can buy because rember that they are holding tons of steel above you. Also stay as far away from the cabel on a come along when your using it. Also when your streching fence with one hook it to your truck not a tree or a post because your asking for trouble.
We were trying to pull a dozer out of the tundra on Shemya one time and I remember when the cable (a BIG cable) broke. Talk about a mean sound when that went flying by. We had a healthy sized dozer buried almost to the hood and had just about every other vehicle availble yanking on it. That cable had a lot of pressure on it.
______ALWAYS wear proper footwear. I dropped a full gallon paint can on my toe yesterday. My daughter learned a few new words on that one.
I didn't bother w/ the doctor but there is no doubt it's broke. Not like they could put a cast on it. So now I'll just walk funny for a while.
Done that.Last Oct. I ran into the shed for something minor(can't even remember what is was).Turned out, I had to move a fender to get to it and dropped it right on my big toe. Needless to say I put on shoes first now. Problem is that when it starts to heal and it quits hurting you start putting weight on it again. I've broke it at least 6 or 8 times since and it still bothers me.
If possible let someone else in the family know you are working under the car just in case you get stuck, pass out, have a heart attack, knock your self out etc. Once knew a guy that had a transmission slip & fall on him as he was installing it. He laid there for a few hours till someone heard him hollering.
#29
#30
Do store paint in proper locations away from heat and outside the living portion of your house. A friend was storing a gallon of very expensive laquer in his bed room. While moving it off the shelf it slipped and burst open when the can hit the floor. The fumes were terrible and he wanted to get it cleaned up quickly before his wife got home. He used a shop vac to vacuum it up. Unfortunately, the paint caught fire when it got inside the shop vac. His house was about half gone when his wife got home! John :-staun
