Camber Bushings
Old Jun 28, 2003 | 05:32 PM
95_Ford XL's Avatar
95_Ford XL
Camber Bushings
My tires are looking like / \ is it hard to put them in? The alignment shop charges $50.00 for both sides.
Thanks Mike
Old Jun 28, 2003 | 06:28 PM
rclarke's Avatar
rclarke
Camber Bushings
The shims are not hard to put in but you need the alignment machine in order to know what size to install. Then the toe-in will be out of spec and you will need the alignment anyhow.
Old Jun 28, 2003 | 08:08 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
Camber Bushings
if your tires look like that i would try some new coil springs
Old Jun 28, 2003 | 10:47 PM
BBiffle's Avatar
BBiffle
Camber Bushings
Mine are doing that too, anyone know how hard it is to replace the front springs on a 91 f150
Old Jun 29, 2003 | 12:54 AM
95_Ford XL's Avatar
95_Ford XL
Camber Bushings
I got 2inch drop springs on mine making it give me neg. camber
Old Jun 29, 2003 | 07:11 AM
DCN's Avatar
DCN
Camber Bushings
Had similar problem. Truck drifted to right. Not much but really annoying. New shocks were bad:
4 new shocks NAPA Sensatrac buy $60 and installed $17 each
When installing new shocks found out front right coil spring was broken. Springs not in stock:
2 new coil springs buy $116 and installled $68 each
Advised to drive it for a week or two come back in for alignment (no charge)
Could not get camber adjustment right and installed 2 new camber (2 degree) bushings buy $50 and install $68 each.
Drives straight as an arrow no drift at all.
