Thin chrome side trim
Old Jan 30, 2014 | 11:37 AM
Mr7.50headsup's Avatar
Mr7.50headsup
Im looking for a set of thin chrome side moldings for a short bed. I know these are not reporduced so im hoping somebody will see a set.
I posted this in the WTB but also figured id post it here too. If your like me you notice every dentside on the road or in a yard so maybe somebody will see a set and think of me.
have a set or found one please PM me.
thanks
Old Jan 30, 2014 | 11:43 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Good luck on a finding a short bed set, you would be better off finding some hens teeth, and a pallet of OEM push bars.
Hope someone has a some for you.
Old Jan 30, 2014 | 11:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Mr7.50headsup
Im looking for a set of thin anodized aluminum upper side moldings for a short bed.
I know these are not reproduced so im hoping somebody will see a set. Have a set or found one please PM me.
1973/79 F100/350 Styleside upper side mouldings without vinyl inserts:
The R&L specific front fender, R&L specific door, R&L specific cab corner (except Super Cab) mouldings are the same.
Only the length of the R/L (same) quarter panel (bed side) mouldings are different.
D3TZ-9929038-F .. Quarter Panel Moulding without vinyl inserts-6 1/2' Bed / Right/Left is the same / Obsolete
Old Jan 30, 2014 | 01:51 PM
Mr7.50headsup
Haha yea i hear ya. Im still holding out hope cause it will cost me a bunch to get two rear standards and a full set of clips. Im holding out for a full set and the truck has all the clips for the thin except 3 of them.
Old Jan 30, 2014 | 01:57 PM
Mr7.50headsup
Just to be sure, the side moldings to the 70-72 DO NOT fit, correct? they look exactly like what i have seen for examples and the clips look the same.
Old Jan 30, 2014 | 02:05 PM
NumberDummy
1973/79 F100/350 Styleside upper side mouldings without vinyl inserts.
1970/72 is not the same!
Old Jan 30, 2014 | 03:56 PM
GM4WALLS's Avatar
GM4WALLS
Pic of what you are referring to? I took all the side trim off my short bed donor truck. If it is what you are looking for, then I will give it to you.
Old Jan 30, 2014 | 06:21 PM
Mr7.50headsup
Numberdummy thank you for clearing that up, didn't think so bed had to ask.
Here's the best picture I can find of the trim.
Old Jan 30, 2014 | 06:32 PM
Dave145's Avatar
Dave145
I've only seen that trim once...and its on my "new" drivers door
Old Jan 30, 2014 | 06:38 PM
51fordf5's Avatar
51fordf5
Well... Worst case, if you can find it for a long bed, you can probably cut a section off the front of the bed and cap it off. I know nobody wants to cut stuff like that, but I figure if nobody else is going to use it then why not. Especially since the short bed stuff you want is obsolete.
Good luck
Old Jan 30, 2014 | 06:54 PM
GM4WALLS's Avatar
GM4WALLS
That's not the trim I have, sorry.
Old Jan 30, 2014 | 08:10 PM
VocaTexas's Avatar
VocaTexas
If you find any, be sure and get all the clips, too. They aren't reproduced either.
Old Jan 30, 2014 | 08:25 PM
NumberDummy
When the mouldings were bought from Ford, they came with the clips.
Upper: Fender & Cab Mouldings / Lower: Bed and Tailgate Mouldings.
Two letter codes in circles are the specific clips and their locations. Listed separately.
Be aware that new/used car dealers would install 'gypo' (aftermarket) side mouldings on 'plain jane' Customs to dress 'em up. Some of these mouldings clipped on, some came with adhesive backing.
Old Jan 30, 2014 | 08:48 PM
grinnergetter's Avatar
grinnergetter
I have a complete set but longbed....I usually save all the clips. If anyone has a pic of the clip I might be able to help out.
Old Jan 30, 2014 | 08:51 PM
grinnergetter
Well nevermind...I could just see which ones fit....duh!
