scan gauge II
Old Jan 29, 2014 | 05:10 PM
efiggs01's Avatar
efiggs01
scan gauge II
So, I just got the Scan GaugeII and I want to know what most people suggest monitoring on the F250 6.0 ?
Reason I got the gauge was do to a issue I noticed today!
I was playing in the snow today for about 15min or so and as I was giving the truck some throttle I noticed it bogged down for a sec almost like it wasn't getting any fuel . I kinda got scared like " what the @#%$ , I hope I wasn't to rough on it or stayed in the throttle to long and hurt something in the motor etc...? "
Maybe a little paranoia but after that had happened , I drove off and it just seemed as if it had lost a little power or was just a little sluggish. The truck has about 41,000 miles on it (2007) and hasn't had any mods done to it at all.
So , I said " you know I been seeing everyone suggest that you have a ScanGaugeII to monitor the trucks values and certain things that the normal display isn't as accurate on or just doesn't show at all. Hense the ? "what should I be monitoring on the truck with the gauge and keep my eye on"?
Please let me know some advice if you have anything solid for me !!! PLEASE!!
Thanks
Old Jan 29, 2014 | 05:35 PM
BLADE35's Avatar
BLADE35
UPDATED SYNC CODES FOR SGII
FICM SYNC= 07E02209CD 0462050906CD 3601 000100010000 FICM Sync (0=No, 1=Yes)
CMP/CKP SYNC= 07E02209CD 0462050906CD 3701 000100010000 Camshaft & Crankshaft in sync (1 = in sync, 0 = not in sync)
V-REF
TXD=07E0221155
RXF=046245110655
RXD=3010
MTH=006433330000
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
BOOST (BST)
TXD= 07E0221440
RXF= 046285140640
RXD= 3010
MTH= 01220320****
NAME=Boost (PSI).
In order to get the proper boost value enter the MAP XGauge. Get a reading
from it with the key in the on position but the engine off. Based on the reading change
the last 4 digits of the MTH value that corresponds to your reading in the table to the
right.
12.6 - - FF82
12.5 - - FF83
12.4 - - FF84
12.3 - - FF85
12.2 - - FF86
12.1 - - FF87
12.0 - - FF88
11.9 - - FF89
11.8 - - FF8A
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
MAP and Volts should already be in the gauge.
MAP Voltage (Volts)
TXD: 07E0220900
RXF: 046205090600
RXD: 3010
MTH: 000104000000
NAM: MPV
Note: This one seems a bit odd, but try it out and let me know if you need finer resolution. This one will go by whole numbers, but the range is something like +/- 32 Volts which seems weird for a sensor – they’re usually 0-5 volts
EP Volts (Volts)
TXD: 07E02216AE
RXF: 0462451606AE
RXD: 3010
MTH: 000100800000
NAM: EPV
Note: This one may have weird readings if the values get to high, let me know.
Glow Plug Coil Time (Seconds)
TXD: 07E0221450
RXF: 046205140650
RXD: 3010
MTH: 000100080000
NAM: GPT
Glow Plug Light On
TXD: 07E0221667
RXF: 046225160667
RXD: 3201
MTH: 000100010000
NAM: GPL
Glow Plug Lamp On Time (Seconds)
TXD: 07E0221451
RXF: 046205140651
RXD: 3010
MTH: 000100080000
NAM: GPT
MAF Voltage (volts)
TXD: 07E0221177
RXF: 046245110677
RXD: 3010
MTH: 000100250000
NAM: MFV
Old Jan 29, 2014 | 05:59 PM
efiggs01's Avatar
efiggs01
V-REF
TXD=07E0221155
RXF=046245110655
RXD=3010
MTH=006433330000
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
BOOST (BST)
TXD= 07E0221440
RXF= 046285140640
RXD= 3010
MTH= 01220320****
NAME=Boost (PSI).
right.
12.6 - - FF82
12.5 - - FF83
12.4 - - FF84
12.3 - - FF85
12.2 - - FF86
12.1 - - FF87
12.0 - - FF88
11.9 - - FF89
11.8 - - FF8A
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
MAP Voltage (Volts)
TXD: 07E0220900
RXF: 046205090600
RXD: 3010
MTH: 000104000000
NAM: MPV
EP Volts (Volts)
TXD: 07E02216AE
RXF: 0462451606AE
RXD: 3010
MTH: 000100800000
NAM: EPV
TXD: 07E0221450
RXF: 046205140650
RXD: 3010
MTH: 000100080000
NAM: GPT
Glow Plug Light On
TXD: 07E0221667
RXF: 046225160667
RXD: 3201
MTH: 000100010000
NAM: GPL
TXD: 07E0221451
RXF: 046205140651
RXD: 3010
MTH: 000100080000
NAM: GPT
MAF Voltage (volts)
TXD: 07E0221177
RXF: 046245110677
RXD: 3010
MTH: 000100250000
NAM: MFV
any idea what might have caused the issue I briefly described in my first post?
Old Jan 29, 2014 | 06:58 PM
worldcat's Avatar
worldcat
I'm new to having the Scanguage II also. I got mine about a week ago. I've researched ALOT over the past few days to learn what to monitor as well as what these things mean, since I am by no means a mechanic.
The stuff that Blade35 shows above is mostly what I have now loaded. If you do a google search for example "ICP, or IPR or ICV, you will find yourself directed back to posts by guys like blade35, cheezit, and other knowledgeable folks who are helping people like you and I. You can learn fairly quickly things like the acceptable deltas for your engine coolant vs. oil temp and what causes the problems like clogged coolers etc. You can figure out what the correct voltages are for the FICM and pressures for the injectors.
I had to look up every one of these things just to understand what they stood for.
I'm currently putting together a spreadsheet at KOEO, LI, HI, at starting temps. and then at fully warmed temps. Once I get it all together, I'm going to post it and get any feedback I can as to whether everything looks OK. I think it will since the truck is running fine.
That will give me a starting point to look at should something go wrong. For example, I'm getting ready to flush my cooling system. I want to be sure once I run VC-9 through it, that, I don't accidently release any particles that might clog the oil cooler causing the engine oil temp. to exceed the coolant temp by more than 15 degrees.
Do the research and reading for a few days and some of it will start to make sense. Also, read the tech guides on this site. Tons of info there.
Maybe this is redundant and you already know, if so, I apologize for rambling on.
Good Luck!
Old Jan 29, 2014 | 07:14 PM
efiggs01's Avatar
efiggs01
thanks guys for all your replies ! keep em coming !!
Old Jan 29, 2014 | 07:44 PM
BLADE35's Avatar
BLADE35
Lots of Ideas on the problem but get the gauge loaded and then use the below to verify readings
SENSOR OPERATING VALUES PDF
https://www.ford-trucks.com/forums/a...1&d=1364848489
Old Jan 29, 2014 | 09:05 PM
efiggs01's Avatar
efiggs01
will do ! thank you for your help as usual . Im sure it wont be the last time ! Hope to be over this noob status A>S>A>P
Old Jan 30, 2014 | 09:48 AM
efiggs01's Avatar
efiggs01
test results from SGII
V-REF
TXD=07E0221155
RXF=046245110655
RXD=3010
MTH=006433330000
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
BOOST (BST)
TXD= 07E0221440
RXF= 046285140640
RXD= 3010
MTH= 01220320****
NAME=Boost (PSI).
right.
12.6 - - FF82
12.5 - - FF83
12.4 - - FF84
12.3 - - FF85
12.2 - - FF86
12.1 - - FF87
12.0 - - FF88
11.9 - - FF89
11.8 - - FF8A
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
MAP Voltage (Volts)
TXD: 07E0220900
RXF: 046205090600
RXD: 3010
MTH: 000104000000
NAM: MPV
EP Volts (Volts)
TXD: 07E02216AE
RXF: 0462451606AE
RXD: 3010
MTH: 000100800000
NAM: EPV
TXD: 07E0221450
RXF: 046205140650
RXD: 3010
MTH: 000100080000
NAM: GPT
Glow Plug Light On
TXD: 07E0221667
RXF: 046225160667
RXD: 3201
MTH: 000100010000
NAM: GPL
TXD: 07E0221451
RXF: 046205140651
RXD: 3010
MTH: 000100080000
NAM: GPT
MAF Voltage (volts)
TXD: 07E0221177
RXF: 046245110677
RXD: 3010
MTH: 000100250000
NAM: MFV
ICP= 581/583 @ idol
EBP= 17.4 @ idol
FMP= 48.5/49.5 @ idol
FLP= 14.0 steady @ idol
SYC= 1
So , what next ?
Old Jan 30, 2014 | 11:23 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Just to add a little info. A few suggestions.
ICP and IPR go together for a good look at the high pressure oil system.
MAP, BARO, and EBP go together and give you a look at intake pressures (boost). You can add BST to this list also, but I believe it's calculated using the previous numbers.
You can watch several voltages at the same time.
You can watch several temps at the same time.
Watch 3 temps and fan speed sensor (FSS).
Here's a quick video on how to put the numbers in:
Entering codes on SGII
Here is a list of codes you can use for a 6.0 powered truck(there are more):
https://www.ford-trucks.com/forums/a...8&d=1337911266
Here is a thread with a good list of what all the sensors SHOULD read:
Operating values
https://www.ford-trucks.com/forums/1...st-please.html
And just so you can figure out what all these letters mean:
Acronyms
https://www.ford-trucks.com/forums/821641-acronyms.html
Hope I ain't overloading you but this info will get you a long way in working on your truck. It is a lot of stuff but you don't have to know it all as long as you know how to find it.
Also, in this thread, there is spreadsheet that is very handy for keeping track of your numbers. (Thanks Piolet)
https://www.ford-trucks.com/forums/1...-attached.html
Old Jan 30, 2014 | 12:32 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here is a video of live running with x-gauges on a 6.0L.
(By the way, I entered gauges alphabetically from gauge 24 - 0, xgauges scroll starting at #24)
Old Jan 30, 2014 | 03:48 PM
efiggs01's Avatar
efiggs01
Ok , So I have spent a good portion of my day just running numbers through all the great codes and advise you guys gave me and the truck checks out healthy as can be according to the numbers on the SGII . So , a bit relieved I am for sure !
I am wondering at this point if it may have just been gelling in the fuel ?
So , I put a ADDITIVE in to stop gelling in the fuel and the truck seems to have regained the lost power now since its been a several hours and some miles later.
Knock on wood!
I really hope this is the cure for whatever the ailment was this morning and yesterday. We normally don't get these extremely low temp here !
If you guys think of any other advise as to my issues since the numbers have checked out , keep the comments coming to me as long as there fresh !
You guys are great !! Much appreciated help here in FTE !!!
Old Jan 30, 2014 | 05:57 PM
KIDkiser's Avatar
KIDkiser
not to hi-jack op,but I ordered a pre programmed scangauge from BPD,will it have everything on it that I need?
Old Jan 30, 2014 | 06:08 PM
efiggs01's Avatar
efiggs01
i don't know what they mean by pre programmed but the one I bought a scanner
from AutoZone and it is has pre-sets in it already . If you mean programmed to have all the gauges you need I don't know . They should explain what they mean a little better .
How much is it costing the pocket if you don't mind telling me?
Old Jan 30, 2014 | 07:06 PM
KIDkiser's Avatar
KIDkiser
it was 10 dollars more than advance auto wanted,and its been so cold here I figured it would be worththe 10 dollars to not sit out in the cold to program the thing.
Old Jan 30, 2014 | 07:56 PM
05F250DSL's Avatar
05F250DSL
Was the snow above your bumper? The air intake is in The left side if the grill next to the headlight if you were bustin drifts you could have packed some snow in your air filter. That would def big you down for a bit until it melted off. It warns about this from heavy snow or rain i the owners manual.
