6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4L Codes codes codes!!!!
Old Jan 29, 2014 | 11:24 AM
ajmicek's Avatar
ajmicek
hey folks,
got in the 6.4 yesterday and check engine light came on. Using my SCT livewire, i got the following trouble codes: B1602 and P1910. I also got the following vehicle stragety codes: FS0L20 and TQJE5.
I haven't gotten much help from online sources (they're all pretty much different and hard to trust) so any help would be greatly appreciated!
thanks!
Aaron
Old Jan 29, 2014 | 07:51 PM
slowmans's Avatar
slowmans
your vehicle strategy codes is just your "trucks code" it means nothing other than the specific code for your truck. I can't find the other 2?
Old Jan 29, 2014 | 08:26 PM
senix's Avatar
senix
P1910 Reverse Lamp Control Circuit / Open
B1602 Partial PATS Key was Read
Old Jan 30, 2014 | 06:48 PM
GHeTTo JOe's Avatar
GHeTTo JOe
your programmer could be causing issues. id re-install it see what it does. also do you have any thing else on your key ring to mess with the key transponder? aftermarket remote start? how long has the programmer been installed?
Old Jan 30, 2014 | 06:52 PM
senix's Avatar
senix
Might also be a battery issue with the cold weather effecting the tuner.
Do you get a check brake system message at all?
Old Feb 5, 2014 | 10:51 PM
665 Almostevil's Avatar
665 Almostevil
i get the check brake system message what is that?
Old Feb 6, 2014 | 05:04 AM
senix's Avatar
senix
check brake system message for the 6.4 is a direct indicator that the batteries are weak.
kbf1961
Oct 17, 2015 10:05 PM
Treytaw
Apr 19, 2013 06:23 AM
Gmangh15
Dec 14, 2011 10:11 AM
eco
Jan 27, 2006 09:12 PM
YJoffroad
Mar 4, 2004 02:55 PM
