help! 69 302 won't start
Old Jun 28, 2003 | 11:55 AM
erk69's Avatar
erk69
my 302 won't start after removing the distributer to get to my temp sending unit. i mark the position on the block and distributer slowly and carefuly replaced and tried to start, nothing, it turns over but won't fire up. why?? need help.
Old Jun 29, 2003 | 01:29 AM
Chris_ce's Avatar
Chris_ce
did you get your rotor set back right?
Old Jun 29, 2003 | 03:53 AM
baileybilt's Avatar
baileybilt
is it back firing? or firing at all? if it is then its probably out of time so you will need to pull it back out bring number one cylinder to the top and reset it with the rotor in the right position.
Old Jun 30, 2003 | 01:19 AM
MuchToMyDelight's Avatar
MuchToMyDelight
If you unhooked any wires, make sure they are where they are supposed to be. Also check your points.
Old Jul 20, 2003 | 05:27 AM
Scooter29's Avatar
Scooter29
Put the ngine back to the #1 cylinder at top dead center. From the mark on your distributor, turn the rotor(your cap is off) to line up with your mark, wich should be the #1 spark plug and cylinder. Put her in and Happy Trails!!! Good luck....
