Sloppy Steering Help
Old Apr 2, 2014 | 07:28 AM
  #46
CGMKCM's Avatar
CGMKCM
If you are going to spend the $$$ to replace the steering box, I would also install a power steering system filter. I found mine at Napa, PN is 18514 for the 3/8ths size inlet/outlet. The filter is mfg by Magnafine and has a magnet and a serviceable filter screen.
I had a problem a couple years back with my steering system, crud from the failing pump was deposited in the steering box and the hydra boost unit. The steering would stick and then release. I ended up replacing all three components and installing a filter.
Old Apr 2, 2014 | 08:06 AM
  #47
snakedoc's Avatar
snakedoc
the box was paid of as it was under warranty. and yes most of AZ parts are junk but the warranty vs the cost of the redhead i had to try.
IrishMike
Nov 29, 2016 05:23 PM
TSmylie
Aug 5, 2014 08:04 AM
Bigblue351
May 23, 2012 10:44 AM
pipman76
Feb 18, 2008 06:00 PM
Moq145
May 10, 2006 01:05 AM
