header help
Old Jan 27, 2014 | 10:12 PM
eddie76's Avatar
eddie76
header help
Hi fellas, in need of help. Ive got a 99 302 gt40p engine off an explorer ive want to use in my 76 f150. Need help finding some long tube headers that fit, upgrade on camshaft and valve springs. My truck is a short bed, 2wd, with p/s and a/c. Any help and suggestions would help. Thanks...
Old Jan 27, 2014 | 10:17 PM
blue04.5's Avatar
blue04.5
I have summit brand long tubes in mine. Virtually same truck, is your standard or auto trans? Mine is 4spd and I don't have ac, I do have "P" heads.
Old Jan 27, 2014 | 10:27 PM
eddie76's Avatar
eddie76
It's automatic blue04.5. Would u happen to have a part number for ur headers? thanks for the help.
Old Jan 27, 2014 | 10:51 PM
blue04.5's Avatar
blue04.5
Should be
SUM-G9032
Old Jan 27, 2014 | 11:31 PM
eddie76's Avatar
eddie76
thanks blue, i'll look em up. What type of gasket did u use? got any pics of ur engine?
Old Jan 27, 2014 | 11:45 PM
blue04.5's Avatar
blue04.5
Things worth mentioning: I bought a cut to fit set of 8.5mm spark plug wires from jegs with bendable socket ends. The last picture there shows you where the header flange needs clearance so you have sparkplug socket room to remove spark plugs without header removal. You can kind of see a scratch through the rust spot on the flange next to the plug boot that material needs to come off.
On edit: Forgot, I just went to napa and got a set of gaskets for a 302.
Old Jan 28, 2014 | 12:07 AM
eddie76's Avatar
eddie76
Nice pics there. thanks blue.
Old Jan 28, 2014 | 08:50 AM
DESERTBEAST73's Avatar
DESERTBEAST73
I too went with the summit headers..tight fit in my 73 with gt40p's. I did have to trim the passenger side motor mount to make some clearance for them..and had to trim down the flanges as well, all in all for the price not a bad set imho
Old Jan 28, 2014 | 09:10 AM
DESERTBEAST73
not a very good photo
Old Jan 28, 2014 | 11:51 PM
eddie76's Avatar
eddie76
thanks for the info desertbeast73.
Old Jan 29, 2014 | 05:14 AM
boxer.fan's Avatar
boxer.fan
That 302 engine looks tiny in that engine bay.
Old Jan 29, 2014 | 04:15 PM
B.Petry's Avatar
B.Petry
Sure is clean though . How much difference did you gain with the P's do you think ?
Growing up around the dragstrip , I remember seeing headers that were blue and some were orange , besides the average black and silver or wrapped .
Its a wonder companies don't do that anymore , with all the retro and nostalgia rage .
Old Jan 29, 2014 | 04:32 PM
DESERTBEAST73
yeah that engine sure looked a lot bigger outside the truck.
As far as gains with the P's i don't have any numbers yet the old girl is still up on blocks.
Old Feb 17, 2014 | 06:41 PM
eddie76's Avatar
eddie76
gt40p headers
Originally Posted by blue04.5
Should be
SUM-G9032
Blue could u verify that header part number for me? Ordered g9032 but flange bolts to head holes are way off, theyre horizontal. Thanks.
Old Feb 17, 2014 | 06:43 PM
eddie76's Avatar
eddie76
302gt40p headers
hi desertbeast could you verify the header part number ur running on ur p heads plz?
