starter no engage
Old 11-11-2003, 07:54 PM
56f600's Avatar
56f600
56f600 is offline
starter no engage
I got my '37 dumptruck freed up and tried to start, but starter doesn't want to engage flywheel. Any suggestions?
Old 11-11-2003, 09:35 PM
46fordtruck's Avatar
46fordtruck
46fordtruck is offline
Starter spins, but doesn't engage the flywheel? Are there any grinding noises, or just the starter spinning? If no grinding, just the starter spinning, then it's probably the Bendix drive on the starter isn't sliding to engage the flywheel. Other option...the teeth on the flywheel are chipped and broken, so they can't engage with drive.
Old 11-11-2003, 10:45 PM
56f600's Avatar
56f600
56f600 is offline
She spins nice and quietly. I tried rolling engine by hand thinking I had a bad spot on ring gear, didn't help. What is the procedure for removing starter and fixing bendix? Thanks
Old 11-11-2003, 11:14 PM
mtflat's Avatar
mtflat
mtflat is offline
Probably have a broken bendix spring. There are two long bolts that go the length of the starter housing and thread into the bell housing - unscrew them (but don't remove them) and the starter will come out. Watch that you keep the starter housing ends in place, cause with the bolts loose it'll come apart. A couple of coarse threaded nuts on the bolts will hold it together while you work on the bendix.
The bendix spring is held on with 2 bolts with lock-tab washers. Make sure you reinstall them correctly with the new spring. Fairly simple repair, but make sure you retorque the spring bolts - and a little loc-tite is recommended. I've had the bolts back off and fall into the flywheel housing (twice). Good luck.
Christie1984
1997-2006 Expedition & Navigator
24
01-09-2023 07:48 AM
hwoolsey
13
07-02-2020 01:50 AM
learpilot
06-20-2016 03:47 PM
jhoopman86
1978 - 1996 Big Bronco
08-04-2010 09:30 AM
boothtec
02-04-2008 09:42 AM
Quick Reply: starter no engage
