460 Gas Stalling
Old Jun 28, 2003 | 08:08 AM
rameier's Avatar
rameier
Angry 460 Gas Stalling
My 1989 460 gas stalls during low speed deceleration. Otherwise the truck runs excellent. Additionally when warmed, the idle will be lower of course and will only come up when I put it in gear and then occasionally stalling.
I think I've narrowed the problem to the TAB or the MAP sensor.
Any ideas?
Old Jun 28, 2003 | 05:01 PM
LxMan1's Avatar
LxMan1
460 Gas Stalling
I am assuming that it is fuel injected? If so, I would look into the IAC idle air control. It should be on the side of the throttlebody. It may need cleaned or replaced. It is held on by 2 8mm headed bolts and has 2 wires going to it. This is what controls the idle speed.
Jimmy
Old Jul 10, 2003 | 07:45 AM
rameier's Avatar
rameier
460 Gas Stalling
I replaced the IAC idle air control valve. The idle is now smoother, but not at start up. It is still will look for a stable idle.
I still get the occasional stall during deceleration. Additionally, I had the valve body cleaned a short time ago.
Thanks
Old Jul 10, 2003 | 10:18 AM
airharley's Avatar
airharley
460 Gas Stalling
OK shot in the dark, Iam not much on EFI systems but could your EGR be stuck? If you can try to push the diaphram in and see if it moves. Or if you can't get your fingers on it use a hand held vacum pump to open it. And remember a lot of auto supply stores do test your computer for free and pull codes for you.
Old Jul 16, 2003 | 07:54 AM
rameier's Avatar
rameier
Thumbs up 460 Gas Stalling
Turns out it was a vacuum leak at the PVC valve. Found it by just dumb luck.
