HVAC controls
Old Jun 1, 2002 | 01:19 PM
enduringexplorer's Avatar
enduringexplorer
HVAC controls
A friend of mine has a '95 Econoline. The heat-a/c mode control turns the a/c compressor on and off, but the air flow is constant through the defroster vents. I can't seem to locate the flow control doors on the truck. Does the dash need to come out to access the doors?
Old Jun 1, 2002 | 06:03 PM
mantta's Avatar
mantta
HVAC controls
Old Jun 2, 2002 | 08:11 AM
Lightning2Fast's Avatar
Lightning2Fast
HVAC controls
take the vacuum motor access door off. it is located on top of the dash. there you will find two vacuum motors. i bet one of the vacuum lines came off or one of the motors has failed and doesnt hold vacuum.
Old Jun 3, 2002 | 03:19 PM
enduringexplorer
HVAC controls
The dash cover/pad is one piece. There are no separate openings except for the instrument cluster and the radio/hvac controls. I guess that means the whole dash has to come out. I wanted to make sure before I took it that far apart. Thanks for the help.
Old Jun 3, 2002 | 08:14 PM
Lightning2Fast
HVAC controls
ok im thinking of the newer units. if youve only got defrost then youve got a vacuum leak somewhere in the system. it automatically goes to this as a failmode. but you shouldnt have to pull the dash to gain access to the vacuum motors. check behind the glove box. look good.
Old Jun 4, 2002 | 09:17 AM
enduringexplorer
HVAC controls
No glovebox. This is what gets me. Fords have always been fairly easy to work on, but not this van. I found one door at the bottom of the firewall near the right kick panel. I thought this one controlled temp. When I open it by hand it sounds like rushing air, but it doesn't change anything. I am going to try to look at a manual today.
