clutch recommendations
Old Jan 26, 2014 | 06:07 PM
phaethon's Avatar
phaethon
Hello everyone,
It is time for a new clutch in my 79 150 4x4. It's on 35s and geared down to 4.56. I would like to go with a stronger-than-OEM clutch this time around, in the $300-400 price range.
I took a peek and found some from RAM, Centerforce, and Hays, and I was wondering if anyone has experience with these clutches. Or, if you have one you particularly like for around that price, please let me know. Thanks.
-E
Old Jan 27, 2014 | 01:48 AM
smokenchoken's Avatar
smokenchoken
what motor?.... my kind of cheap "Brute Power" clutch has served me great for the last 4 years and lord knows i have not been nice to it in any way shape or form.... Brute Power Clutches -
Old Jan 27, 2014 | 04:33 AM
gatorfor88's Avatar
gatorfor88
Really cant go wrong with any/all mentioned above as long as they are not sourced out from some third world country. Just dont ever cheap out and buy any of the parts house brands made in china,indonesia,etc. I promise you wont be happy with them in 2 years.
Old Jan 27, 2014 | 09:12 AM
phaethon's Avatar
phaethon
Ok, thanks. It's a 351M with a fairly aggressive cam and some other go fast parts. It burnt the stock clutch up in about a year and half.
Old Jan 27, 2014 | 11:22 AM
smokenchoken
oh and welcome to FTE.... the main thing for making a clutch last is getting it adjusted right.... a slipping clutch goes out quicker
Old Jan 28, 2014 | 01:06 PM
79F150400M's Avatar
79F150400M
I put a BWD Brute Power in mine in 1993. Still going, but I cant light up the tires. Maybe because its the original 11" clutch from the 351. Not improtant anyways. Damn good clutch set though....
Old Jan 28, 2014 | 10:00 PM
7636074460's Avatar
7636074460
http://www.summitracing.com/parts/ct...rd/model/f-250
does anyone know if i could get just this disc and use it with a regular normal clutch kit? or are the pressure plates specific? im having the same problem, i hit third and smoke it, if i had this disc it may improve
Old Feb 14, 2014 | 03:16 PM
phaethon's Avatar
phaethon
one more thing...
Thanks for the recommendations on Brute Power. They are super cheap! And if they're quality clutches I'm happy to save money.
I have another question someone here is bound to know. My 351 flywheel has the 11" clutch with 12 5/8" bolt pattern. Since it's the larger circle, does this mean I can put a 12" clutch for a 400 in there? Do they have 12 5/8" circles?
Happy wrenching, everyone.
-E
Old Feb 14, 2014 | 06:15 PM
BogTroll's Avatar
BogTroll
This may not be a very good answer to your question, but the only difference between the 351M and the 400 is the crank and the pistons. I just ran out to the shop and measured mine from a 400 that I'm rebuilding for my '78 F350 dump. It has the same bolt pattern and a 12" disk.
Old Feb 20, 2014 | 09:16 AM
yankeerebel's Avatar
yankeerebel
I went with a centerforce dual friction because I figured I'd be spinning large tires and pulling a heavy weight and I needed all the grip I could get. Ran me about $300+ if I remember but it's amazing.
A little stiff too. There's really no feathering at all; its either engaged or not, no inbetween.
Old Feb 20, 2014 | 10:10 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here is some info on the clutch to consider, I believe it does matter if you have a 351M and a 11" cause, I had the same issue and a 12" would not work. They gave me the wrong part # (and a 12" clutch) because I was un-informed when I went in to the parts store.
""""The 400 uses a 12" clutch and the 351m uses a 11"
Hard to tell what was actually put in everyone of these trucks, but here are the part numbers.
D7TZ-6375-D .. 400 Flywheel-Use with 12" clutch.
D7TZ-6375-E .. 351M Flywheel-Use with 11" clutch.
I've actually also been looking for a 12" flywheel with no luck for a while."""""
Above info thanks to ND.
Just make sure you replace the clutch as a "set", meaning (clutch, pressure plate, throw out bearing and center bushing).
Old Feb 20, 2014 | 01:02 PM
Zemmeron's Avatar
Zemmeron
I just put a centerforce dual friction clutch it in my f-100 a couple months back that's what I would recommend. Operates very nicely!
Old Feb 20, 2014 | 06:18 PM
RumRunner78's Avatar
RumRunner78
Any of you have any experience with the LUK clutch sold by bronco graveyard, etc?
Old Feb 21, 2014 | 10:27 AM
Filthy Beast's Avatar
Filthy Beast
77&79F250 is correct about the clutch.
Even though the 351M and 400 flywheels are the same size (diameter/circumference), and use the same ring gear, the bolt patterns are different. The 400 flywheel's bolt bolt holes are more toward the outward edge of the flywheel, needing a 12" clutch.
Old Feb 21, 2014 | 10:53 AM
77&79F250's Avatar
77&79F250
I only get credit for copy and pasting ND words of wisdom....
