Big setback
Old Jan 26, 2014 | 04:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If you swap rocker assemblies side-to-side, do you end up with a non-drilled rocker stand sitting on a location designed to feed oil to the rockers?
Old Jan 26, 2014 | 06:13 PM
DR Smith's Avatar
DR Smith
Everything was tagged and put in order when it came apart . Rocker holes line up with head . No oil even when heads off , As I only ran the motor for short time before I pulled it down, and it sat for a couple weeks before valve covers came off . I am not sure how much oil I was getting before tear down . The gauge showed 50 lbs . Mechanical gauge ,
Old Jan 26, 2014 | 08:21 PM
Steve's Avatar
Steve
Some of the older cams were crossed drilled, but you rotated the engine while turning the oil pump right? If you did, and still had no oil to the block deck, then if it's not a clogged passage, the the center cam bearing may have rotated, blocking the holes.
GusGus
Dec 6, 2006 05:04 PM
nextse7en
Apr 13, 2005 08:09 AM
bl55army
Oct 15, 2003 09:56 AM
shadetree
Sep 18, 2000 12:42 PM
FORDTRUCKMAN1976
33
Jun 3, 2000 11:23 PM
