Sponsored by: Auxito
Cooling system flush
Old Jan 24, 2014 | 11:25 PM
dvlsmstr's Avatar
dvlsmstr
Anyone ever use CLR (calcium lime rust) cleaner as a cooling system flush? My reservoir is terribly stained and I figured I'd soak it in CLR and thought why don't I just run the stuff through the system for a few hours and really clean it all out.
Old Jan 25, 2014 | 06:26 AM
Spotty's Avatar
Spotty
Man...I have heard bad things with that stuff. Guys have used it to flush out motorcycle cooling systems and it ate in to the aluminum and blew head gaskets. You can pull the hose off that plastic tank and unbolt it and then take it off and just clean that. Be sure to drain down the radiator until it empties that tank.....the level in the plastic tank is the same as the radiator.
Old Jan 25, 2014 | 09:51 AM
dvlsmstr's Avatar
dvlsmstr
Thanks Spotty, that's EXACTLY why I asked before doing it.
Roger T. Pipe
13
Sep 16, 2020 04:34 PM
The Terrible Blob
Jul 22, 2014 12:22 PM
fordrulz
May 1, 2003 08:09 PM
Ken2600
Oct 18, 2002 03:03 PM
