1978 - 1996 Big Bronco
engine oil
Old Jan 23, 2014 | 03:11 PM
f1001969mike's Avatar
f1001969mike
engine oil
hey guys whats up, i just got a simple question for ya, right now im running 10w40 in my 89 bronco, its very cold right now, and it raps for a few seconds on start up after its been sitting. well its coming up on my next oil change and well, im wondering if switching to 5w30 would be advisable , not just for the winter but for the long run too, any suggestions?
Old Jan 23, 2014 | 10:33 PM
swann79's Avatar
swann79
What's your location? I would never run 10W-40 in winter in a Ford small block in Wyoming, unless the engine is an oil burner. I vote for 5W-30 semi-synthetic. If it uses or leaks oil in the summer, then bump it back up to 10W-40.
Old Jan 24, 2014 | 05:55 AM
b4hntn's Avatar
b4hntn
Oil weight and Filter
Start up tapping.
Use only Motorcraft or Purolater oil filter because they have anti drain back check valves. Your filter will not be empty of oil on start up.
Oil weight.
Ford has recommendations on a chart somewhere for year and engine. Start by looking for a sticker somewhere under the hood. Most wear occurs at start up until the oil stabilizes and oil pressure drops a little. I believe the most important oil number is the first one. Lower is better for flow at start up.
https://www.ford-trucks.com/forums/4...20w50-oil.html
Gauge
Get a good truly mechanical oil gauge and disconnect the stock one. Do it for water temp also.
I FINALLY FOUND IT. Everything you need to know and then some...
http://www.boss302.com/oil.htm
Old Jan 24, 2014 | 06:46 PM
greystreak92's Avatar
greystreak92
I will second b4hntn's recommendation on the Motorcraft/Purolator filters. They are the ONLY two with the drainback check valve.
The Carpathia
32
Feb 2, 2012 11:07 AM
oldblue89
15
May 26, 2011 09:32 PM
AyotteBill
Dec 19, 2010 10:06 PM
Americanmadeford
Oil & Lubrication
Sep 11, 2007 10:31 PM
66beater
Jul 25, 2005 08:17 PM
