Differential Gear Oil
[QUOTE=The other Joe;13995887]I would not say that. My tucks have over 150k on them and the LS works fine
brad ... can i infer from your reply that ;
A) i do have a limited slip rear end, and
B) you think that synthetic is the way to go ?
by the way, my truck has a little under 100k miles on it; don't know whether the LS works ( if it has one). changing lube only because i have no idea whether it has ever been done and also because i have a leaking axle seal.
thanks.
thanks.
thanks.
thanks.
typical the bolt that holds it on the diff cover, covers the 1st digit so you will see..
L10 or L55 if it is limited slip
10 or 55 if it is open
I always run synthetic in the rear axle, because that is what it calls for
What a timely thread. I just noticed today that my limited slip rear diff is doing nothing but slipping.
Yes, the tag says it's a limited lip. I changed the diff oil a few months ago. The oil I bought has the friction additive in it, so I didn't add any. Would more friction additive help?
[QUOTE=Diesel_Brad;13996109]
Brad, 150k is great for a factory clutches. I have heard many reports of those being bad by 70k or so.
Maybe the key is proper servicing when the Truck has 30k miles or so.
I know many people never change their diff oils.
I haven't checked if mine works on the new truck yet. It has 170 k so I am not hopeful it works. It would be a pleasant surprise for sure.
Thanks,
Joe W.
Thanks,
Joe W.
Without the additive, the LSD is harsh and doesn't disengage as well.
The life of a LSD diff depends on how it's driven. If you spin the tires excessively, and it catches and only one tire spins, you're burning the clutches. Kinda like slipping the clutch in your trans, it can only take so much before they glaze over.
StrangeRanger
11-14-2001 03:32 PM
