Sponsored by: Real Truck
Help!!!!!!!!!! Heater shut off question.
Old Jun 27, 2003 | 08:51 PM
MarkF250's Avatar
MarkF250
Ok, I did this mod. I tapped into the red vac line and now my Max A/C acts like the defroster with air coming from defroster vents and dash vents. My A/C setting acts like the Max A/C setting. When I turn it off, it has everlasting vaccuum leak sound. What's up? Please help!
Old Jun 27, 2003 | 09:05 PM
theswagg's Avatar
theswagg
Are you sure all the vacuum connections are tight? It sounds like something is wrong. Did you cut the red line away from the white connector and install a tee or did you pull the red line out of the white connector? I've done this on my truck ('99) and it works much better and for only $15. I'm glad someone started this thread on doing the valve. The white connector can come loose easy I noticed on mine and let air in.
Old Jun 27, 2003 | 09:58 PM
MarkF250's Avatar
MarkF250
Ok, Duh....I'm an idiot! When I unplugged the vaccuum harness of 5 vac lines the plastic coupler came off and I reinstalled it upside down.....so, all vaccuum lines were backwards. I was about to fall asleep thinking about it when it hit me what I did. So I went downstairs to fix it. Now, things are exactly they way they should be..COLD!!!!! I love this mod! I'm usually not this stupid!!!!! Take note of my mistake!!
Old Jun 28, 2003 | 09:55 AM
theswagg's Avatar
theswagg
Good job man! Leave an extra flannel shirt in your truck now.
jbedsole23
Mar 11, 2014 06:25 AM
pete315
Jun 8, 2010 07:42 AM
claycomotrucks1991
May 27, 2009 07:04 PM
