Bucking Truck
Bucking Truck
I'll apologize in advance if this has been addressed in posts elsewhere, but I'd like to get a few opinions.
I have a 1958 F100 with a 292 y-block, 2v, 4-speed manual. The other day while driving on the freeway it began bucking violently. I thought it was starving for gas, so I replaced fuel filters, air filter, and even the fuel pump (which had previously been replaced with an electric). None of this seemed to help. I replaced spark plugs and HT leads about 500 miles ago, so I'm assuming they're OK. It seems to start bucking at about 45-50 mph going uphill. Is a carb rebuild the next step, or is there something else that might fix it? New coil maybe? Any suggestions would be appreciated. Thanks.
I have seen a damaged clutch/pressure plate cause bucking under load. However, I'd check float level or even rebuild carb before suspecting that.
Might try a fuel flow test. That would let you know if the fuel line is clogged, has a pinhole leak, or the tank's sock is clogged.
It's funny you mention the clutch. That's something that's been in the back of my mind, as there's been some slippage under load/acceleration. I've also been noticing the "burnt brake" smell lately. I'm inclined to follow that lead before rebuilding the carb since it obviously needs the clutch regardless. I just wasn't sure if that's something that would have caused bucking rather than loss of power altogether. Why would a worn clutch cause that? Would it be the clutch plate slipping then suddenly grabbing the flywheel?
I'll also check the tank sock. The sending unit is in need of replacement anyway, since I'm getting inaccurate fuel level readings (full tank registering as only a quarter).
bucking
I admit this doesn't happen often but I had a car that was only driven for a one week period each year. When I was done driving each time- I would fill the gas tank to the top. After a few years, it drove just fine from full tank down to half. If I let it get under 1/2 it would buck like a bronco! The tank was pulled and had more than 5 gallons of water in it.
