Bluetooth OBD2 Scan Tool/No EOT reading
Old Jan 21, 2014 | 09:03 PM
ToddShroats's Avatar
ToddShroats
My blue tooth scan tool works great but I don't get any reading on my EOT. I have checked it every time I hooked it up and nothing. How can I test the sensor to see if it is working? Or should I look for wiring problem some where on the motor, if so where?
Old Jan 21, 2014 | 09:07 PM
Money-Pit's Avatar
Money-Pit
What bluetooth app are you using?
Old Jan 21, 2014 | 09:53 PM
ToddShroats
BAFX Products Bluetooth OBD2 Scan Tool, bought it on amazon. Seems to work great.
Old Jan 21, 2014 | 10:08 PM
Money-Pit's Avatar
Money-Pit
I think that is the bluetooth adapter itself....that's the one I use with Torque Pro. What device are you viewing your gauges on?
Old Jan 22, 2014 | 08:06 AM
ToddShroats
I use Torque Pro on my Samsung Android Phone.
Old Jan 22, 2014 | 08:08 AM
Money-Pit's Avatar
Money-Pit
Now we're making progress. One of the EOT gauges doesn't work with our trucks. Try the other one, there should be 2 listed. Have you got the custom PID's for the Ford powerstroke?
Old Jan 22, 2014 | 08:17 AM
ToddShroats
I have the custom PID's, I only see one EOT in the list.
Old Jan 26, 2014 | 08:30 PM
ToddShroats
Does any one no why the EOT wouldn't work in torque pro?
Old Jan 26, 2014 | 08:34 PM
copsey's Avatar
copsey
Mine works fine, like Money-Pit said there are two available. Engine Oil Temp and Engine Oil Temperature, you have to use Temp.
Old Jan 26, 2014 | 08:38 PM
Money-Pit's Avatar
Money-Pit
There are 2 for EOT.... one is labeled "engine oil temp" and the other is "engine oil temperature". Try the other one.
I just verified this again on my TP...if you only have one....you have an app problem.
Lookie here....
Old Jan 26, 2014 | 08:50 PM
Money-Pit's Avatar
Money-Pit
^^ Yea, we he said....
Old Jan 26, 2014 | 10:07 PM
ToddShroats
I see two of them, dont know why I didn't see that before. Thanks.
Old Jan 26, 2014 | 11:15 PM
BLADE35's Avatar
BLADE35
Did you ever get a EOT Reading????
If your gauge isn't the problem and its the sensor or wiring it could be the reason your FAN don't work right
Old Jan 28, 2014 | 08:41 AM
ToddShroats
I have found both EOT on my torque pro program and one shows up green indicating that it is working but the temp is 0deg and the other doesn't work at all.
Since the Torque pro is picking up on it but no temp, does that mean the wiring is ok but a bad sensor? I have looked the wiring and plug over and it look ok. If I have the correct plug, I believe it is the one on top of the oil cooler next to the filter.
Old Jan 28, 2014 | 05:05 PM
egregg57's Avatar
egregg57
I had this problem. Look at the string for the EOT in the Torque App. There is an extra symbol, a parenthesis "[" I think. Let me look, I will get back...
