Hub assy torque specs
Old Jan 21, 2014 | 01:30 PM
tcjhkbjt's Avatar
tcjhkbjt
I just replaced the ball joints on my 04 f250. Found somewhere that the bottom is at 70ft pounds and the top at 150ft pounds but what about the hub assy and everything else, what are they?
Old Jan 21, 2014 | 06:48 PM
MisterCMK's Avatar
MisterCMK
Should be 135 lb/ft
Old Jan 21, 2014 | 07:17 PM
Snuggyworm's Avatar
Snuggyworm
i think it may be anywhere between 130 and 135 ft lbs. something like tat.
oh and i think there was something tat said 133 ft lbs. i may be wrong but if i am, don't hold it against me. it may be 133 ft lbs. i just had a light bulb moment.
Old Jan 21, 2014 | 07:22 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Check these:
(if they aren't right PM me, and I can check for the exact torque specs you want)
Old Jan 22, 2014 | 08:05 AM
CPB1's Avatar
CPB1
The front axle was changed in 2005. The 2004 torque specs may be a little different.
Read the procedure carefully, the lower ball joint gets torqued half way first, then upper ball joint, then finish lower ball joint.
Old Jan 23, 2014 | 09:33 AM
texastech_diesel
Token Redneck
Front axle was changed in 01-02, it's been a D60 ever since they ran out of the original solid D50s? I thought just the bearing assembly changed, but the axle hardware was the same since then.
Old Jan 23, 2014 | 04:54 PM
Snuggyworm's Avatar
Snuggyworm
I believe Dana 60s on fronts were for the drw, and I got Dana 80 in the back.
For the srw, Dana 60 or the sterling in the rear. U can tell by the number of bolts on differential cover.
Sent from my iPhone using IB AutoGroup
mmenzies
Jul 11, 2014 04:01 PM
tractorguy1
2004 - 2008 F150
Jul 25, 2012 06:10 PM
homesteader
Nov 18, 2010 03:06 PM
Wodeman
Jun 29, 2009 08:10 AM
1994 F250: 351, C6
Dec 18, 2007 01:11 AM
