loose steering wheel
Old Jun 27, 2003 | 05:07 PM
red79bronco's Avatar
red79bronco
Unhappy loose steering wheel
anyone know how to tighten up tilt steering? tore it apart and it dosen't look anything like the gm ones that are easy to tighten. any help would be appreciated.
Old Jun 27, 2003 | 06:04 PM
Mil1ion's Avatar
Mil1ion
Is it flopping easily?
I bet the spring clips are broken off.
Watch for the *Hawk* he will help you out.
Old Jun 27, 2003 | 06:46 PM
red79bronco
no, it's not flopping around, it is just loose enough to make you think about tearing the column apart.
Old Jul 1, 2003 | 10:22 PM
hawkrod's Avatar
hawkrod
how far have you taken it apart? the most common problem is the two pivot pins work there way out. also the pins that pivot and lock the tilt mechanism are famous for working out one side or another. the last and worst case is the three bolts that clamp the tilt knuckle to the tube have torn free and you need to knock it all of the way down and weld the tube back together. hawkrod
Old Jul 3, 2003 | 04:50 PM
red79bronco
just took it apart enought to see the knuckle. it is back together now. do you know where i can find a diagram. thnx.
Old Jul 3, 2003 | 05:18 PM
Mil1ion's Avatar
Mil1ion
You want a blow-up diagram of how the column is assembled ?
I don't know what Hawk will say but I take them right out of the vehicle and service them.
I'm pretty sure it is the only way.
Old Jul 3, 2003 | 05:34 PM
hawkrod's Avatar
hawkrod
yup, pull and knock it down. its the only sane way. i do dozens of tilts every month but i am sorry to say the only illustrations i have are the factory service manuals (i really don't need them anymore, after about the first 100 or so you sort of have a hard time forgetting how to do it! LOL). hawkrod
Old Jul 3, 2003 | 06:01 PM
Mil1ion's Avatar
Mil1ion
This is the best I can do.
I really recommend getting a Ford Shop Manual on CDRom from motorhaven.
The Original Shop Manual is the mechanic's best friend.
Old Jul 3, 2003 | 06:16 PM
red79bronco
Cool loose steering wheel
ok, thanx, guys. this is my first ford column and it is really different than my jeep ones. i can figure it out now with your help. thanx again.
