single bbl carb for 300
Looking for an exploded view of the single bbl carbruetor used on the 1980, 300 cid, 6 cylinder engine.
Have some parts missing and attemping to identify.
Found exploded view of stock 1980 single BBL carburetor used on 300 cid 6 cylinder engine.
Appears to be a Rochester style M-MV, but carburetor has Motorcraft embossed on the top cover.
Look for a Carter YFA.
Some depends on emissions calibration.
Do you have an electric choke?
Hot air only?
Both?
Carter Y, YF, YFA, YH, YS - The Carburetor Doctor
Carter YF YFA Carburetor | Mikes Carburetor Parts
Hot air only?
Both?
Thank you for identifying the carburetor on the 1980, 300 6 cylinder engine.
Yes, it is indeed a Carter YFA with hot air choke used on Ford trucks between 77 -85
Using the exploded view from Carburetorfactory and
Mikes carburetor parts kit... was able to identify the missing link part between the verticl pump operating lever and the throttle plate shaft.
It is not unusual for Ford carburetors to be branded as Motorcraft or Autolite when made by major carburetor manufacturers like Holley and Carter.
In most cases the only differences are mandated emissions controls like fixed jets or float bowl vents that connect to a charcoal canister.
Some are fitted with electric solenoids controlled by the engine management computer.
I'm glad you were able to find the link you need and hope it is a simple matter to get your carb working right.
iLooknasty
13
Mar 11, 2015 12:33 AM
Rusty_Old_F250
All Other Items for Sale
Jan 19, 2015 04:35 PM
highguy2012
Mar 18, 2012 06:57 PM
apachetech
Jan 3, 2012 11:53 AM
iride
Sep 18, 2010 02:26 PM
