I have a 1987 F-250 4x4 EX cab long wheel base 6.9l Deseil and i need some advice! I am haveing a problem starting in the morings! and i think my switch that changes wich tank its pumping deseil out of i think is going out!
When i'm drivein down the road and on the gas it pours black smoke out the pipes. it idles fine but while sitting and i push in the gas it gives off black smoke then white or blue smoke i cant really tell! SO if anyone can give some advice and suggestions plz email me!
The black smoke is from over fueling, lack of air, or a cold engine. Check your air filter, have your injection pump and injectors cleaned and calibrated. If this doesnt help, you may have low compression.
The black smoke is from over fueling, lack or air, or a cold engine. Check your air filter, have your pump and injectors cleaned and calibrated. If that doesnt help, you might have low compression.
