My first ever "Please Help me" thread (Hard Shift)
a shift kit can, in fact, make a tranny shift hard, and late, but the fact that this shift kit wasn't mentioned earlier has my b.s. alarm ringing loudly.
even so, it's worth your while to determine whether it really has had a shift kit installed and whether an adjustment can be made to it.
haha that's what I was thinking. Is it possible to look for any indications of there being a shift kit installed? I figure it could keep me busy while I want for the code reader to come in.
Thanks to everyone for showing interest. If it wasn't for the replies I've received I would have been one sad new truck owner!
111 - system fine
10 - which I believe is a code reader break or a completion of the test
332 - insufficient EGR flow detected
452 - Vehicle speed sensor fault (VSS)
I'm assuming these are pretty self explanatory but I'm puzzled about the EGR flow. Is that caused by my non functioning smog pump?
I don't want to keep going on about it but I remember the seller of this truck telling me that a code reader would be a waste of money because he already "scanned it and came up with nothing"
Thank you all for your help!
This vintage truck cannot sense EGR flow because the EGR feedback signal is EGR position (EVP) not flow from a DPFE sensor. Since the code came after the "separator" that means it happened sometime in the past.
Code 452 is the most likely cause your transmission shift problem.
Thank you so much for your response! So does that mean the egr is fine?
I kind of feel silly because I didn't know I could perform a KOER test
so I pulled some more codes:172
332
538
536
632
and it also said cyl 8. I checked the manual and it didn't reference this, unless I missed it could someone shed light on it? Love you all
Code 332: EGR valve opening not detected. ( Is the vacuum line connected?)
Code 538: Insufficient RPM change during KOER dynamic response test/ Operator error ( Did you "goose the throttle when you were supposed to?)
Code 536: Brake On/Off circuit failure / switch not actuated during KOER test(Did you step on the brake when you were supposed to?)
Code 632: Overdrive cancel switch not changing state (E4OD) (Did you cycle the OD switch off/on when you were supposed to?)
Looks like the EGR may not be opening (Code 332)
Part of the KOER tests is a display of how many cylinders the PCM is programmed for. In your case 8 cylinders, that is a good thing!
Please prepare for an enormous amount of newb
For the 332 code, could you point me in the general location of the EGR to check?
For the rest: I wasn't sure when to press the accelerator so I just left it to do its thing, ditto for the brake test. I did do the output state check though and that came up ok. For the OD switch not changing state, the button doesn't work at all
I was searching for the VSS while grabbing the codes, is it located on top of the dif "pumpkin" for lack of a better word? Thank you again
If you have the E40D transmission, then it is possible to install a shift kit. The kits are universal and the installer has to select a few things when installing it that will control how hard / fast the shifts are. The settings can be opened up to make things firmer, but not closed down to soften, basically you enlarge holes in a plate, the bigger the hole the harder the shift. If the plate was drilled with aggressive settings then you will need to get a new plate with smaller holes.
EGR valve:
The gray sensor on top of it is the EGR Valve Position (EVP) sensor.
The VSS is located on top of the rear axle "pumpkin"
But they rarely go bad AND many of the aftermarket replacements are inferior quality. I suggest you remove the VSS, inpect it for signs of metal shavings or other contaminants. If there is only a light coating, try wiping it off then re-install. If it has heavy build up then you need to remove the rear axle cover then inspect the bearings, gears, exciter ring teeth, etc.
Assuming there was only a light build up of crud on the bottom of the VSS try driving the truck around a bit, after cleaning it up, to see if the hard shifts return. You also might want to clear the codes before doing this, that way you can start with a clean slate.
If the O/D button is not working it is most likely a bad switch. A replacement can be purchased at many auto part stores under Dorman Part# 49299
Yes the VSS is on top of the rear axle. Remember, the computer can only tell you what it sees as wrong. Just because it says "Vehicle Speed Sensor" doesn't mean the sensor itself is bad. And actually on our trucks the PCM/computer doesn't read the VSS output directly. The signal goes to the PSOM (Programmable Speedometer/Odometer Module) which then re-processes the signal to calibrate it for tire size and gear ratio. This calibrated signal is what goes to the PCM. So, you may have a faulty PSOM, blown PSOM fuse(s), or a bad VSS. Start with checking the fuses in the cab.
As for shift kits, yes you can put a shift kit in there. I'm planning on one for mine, although I won't set it up to shift THAT hard lol. My Thunderbird had the 4R70W in it (an electronic transmission)... I set that one up where it felt like a powershifted manual. It would break the tires loose on the 1-2 shift every time, and sometimes on the 2-3 shift also.
Oh! Thank you so much for all the info. I had to take a day to reread the thread because it seems like my issue is taking forever, I didn't get to really mess with the sensor because of the brutal weather outdoors
and again thanks to everyone who's taking interest in helping me. I really appreciate it. When you mention the PSOM would there be any other symptoms I could look out for before I get to perform surgery? (Sorry but the pc tech in me loves to troubleshoot before getting dirty) Would the speedo be messed up? Pretty much outside of the hard shifting and the perma-off O/D everything seems A O-K. If I manually shift into "2" the truck runs beautifully and I can manually shift through all gears.
Can I ask a question that I was afraid to ask? Is there a chance that there's something mechanically wrong with my transmission? I love my truck and I had plans to make it last forever but if it needs a transmission I may need to call off the engagement before we get married :~(
Thanks again everyone . My appreciation is great and I can't wait to be a contributing member.
The speedometer head very seldom if ever goes bad. The PSOM plugs into the back of the speedometer head.
If the VSS sensor on the rear end or the wiring from the sensor to the dash was bad your RABS amber lamp on the cluster would be flashing also.
The PSOM:
Wiring for a 1995 but yours should be the same:
It does not sound like there is anything wrong with your transmission at this point.
My speedometer is even and accurate my cluster is all clear as far as lights go. My ABS light isn't on and no RABS lamp that I know of
I'm not sure if I missed it but would my code reader pick up a faulty PSOMI did notice that some of the plugs were pretty haggard under the hood. My washer pump connector was packed with this blue corrosion that obviously messed up the connection. My blower resistor was the same way and I had to literally haul it apart and just marette a new one in. Is there a chance that this could be happening? Should I go through any connector I can find and check for that stuff?
again
again
