6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Heating and Cooling issues
Old 01-21-2014, 09:39 AM
Kimani's Avatar
Kimani
Kimani is offline
I took my truck to get an oil change, and the guy that was doing the oil change told me that I was a gallon low of cooling. I did notice while I was driving the heat would blow hot, and when I slowed down and stopped at a light it gets cooler. The guy topped it off with cooling, it seemed to be working fine for about a week. Now it is doing it again. My guess is I'm low on cooling again. My question to you fokes is why am I losing cooling??? Also, I don't see any cooling on the ground but I occasionally smell cooling when I walk pass the truck.
Old 01-21-2014, 10:09 AM
RoofDude's Avatar
RoofDude
RoofDude is offline
More than likely your radiator is leaking at the hose. The clamps for em have changed/upgraded since new. It's typically a pretty slow leak, & hard to notice. It's happened to most of us. I would rarely see anything on the ground either, as it would run down hoses/rails/etc.. Finally I saw a few drops on the ground, kept an eye on it, kept seeing it.... took it in, & had the hoses replaced. It was too late in my case as, a short time later, I had the radiator replaced...
It's a common issue/problem
Old 01-21-2014, 10:23 AM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
I agree, check the radiator seams.
Don't run low on coolant. Causes cavitation and EGR cooler failures.
Waterlogged
10-17-2018 05:37 PM
Courtney Williams
08-11-2018 11:34 PM
waldir cruz
Escape & Escape Hybrid
04-16-2017 07:05 AM
joel79ford
12-26-2011 08:59 AM
dbuck50
16
07-26-2005 08:42 AM
Quick Reply: Heating and Cooling issues
