transmission modulator
Old Jun 27, 2003 | 02:33 PM
maa139's Avatar
maa139
How difficult is it to replace the trans modulator on a 94 Explorer?
Old Jun 27, 2003 | 07:09 PM
rclarke's Avatar
rclarke
The vacumn modulator is a little hard to reach. If you support the transmission and lower the transmission crossmember on the passenger side you can reach in from the rear of the transmission to remove the bolt and the modulator. Do it when the vehicle is cold or at least cool. You will be working very close to the catalitic converter. Be careful not to lose the pin in the modulator and reinstall it with the new modulator. You will lose a little fluid that will need to be replaced.
