F250 1995 pressue test question
Old Jan 19, 2014 | 02:45 PM
Breezland's Avatar
Breezland
I installed new radiator and water pump when I pressure test it holds I assume the thermostat is closed therefore it is only checking system before the thermostat. I have no leaks on hoses or water pump. Should i hook up pressure tester and run engine until it is hot and the thermostat is open? How do I know if thermostat is open? I did it briefly and did get leakage from somewhere not sure where it comes out under the transmission and by the cross member under the oil pan? Pressure fell quite rapidly. Any ideas where the leak may be. Leaks when parked on incline not when flat.
I also I hear hissing noise when I shut engine off. Afraid if may be a head gasket or heater coil.
I see the heater house is high up on firewall on passenger side. Not sure where it routes to finally get to heater coil.
Old Jan 20, 2014 | 04:37 AM
EPNCSU2006's Avatar
EPNCSU2006
The pressure is applied equally to the entire cooling system even with the thermostat closed.
Old Jan 20, 2014 | 09:26 AM
Breezland's Avatar
Breezland
thanks, do you know if the pressure applied with pressure test is a lot greater than what occurs when engine if running normally.
Old Jan 20, 2014 | 10:27 AM
Lead Head's Avatar
Lead Head
General rule of thumb is to put the pressure tester at whatever the cap is rated at. Usually 13-16 PSI.
Make sure the engine is stone cold when doing the test. If you do it on a hot engine, the pressure will drop as the engine cools.
burnse
18
Feb 22, 2018 06:50 AM
hammer65
Dec 26, 2010 05:31 AM
ford4x4956
Jul 1, 2010 09:50 PM
cigarxtc
Aug 17, 2005 04:55 PM
baxy
Jul 23, 2005 01:45 PM
