i forgot....
Old Jun 27, 2003 | 01:29 PM
chalms's Avatar
chalms
i forgot....
Also I had to take it for an emissions test which it passed...however it failed the OBD...with codes..P0171 & P0174...system too lean (Bank 1 & 2). Failure reason...mil light. Can this be covered under any emission warranty?...the dealership says no.
Old Jun 28, 2003 | 12:19 AM
reberhardt's Avatar
reberhardt
i forgot....
If you are referring to your MAF replacement above, then no it is not covered under any kind of extended emissions warranty. Look in your Warranty guide to be sure though. If it is writtin anything like my '97, the only items carrying a longer emissions related warranty are the PCM and catalytic converter. They are covered to 8 years, 80K miles. Unless you are in California, in which case, California requires a lot more items to be covered longer than the standard 3 year/36K warranty.
