EVERYONE NEEDS TO SEE THIS!!!!! Dorman gasket
#31
That's good to hear!
definitely will be doing that, might have to be at that level anyhow for the HPO leak. Either way I'll pick one up as soon as this job is done... Thurs I think.
I put about 30-50k miles a year so we shall see EOT/ECT is always on my SGII screen.
After I get some tires (Feb), I will do that for sure! Might as well keep one handy, if I don't use it my neighbors might . 4 of the 9 houses on this street have a 6.0
******** charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript">*********>
But if you want Take that Price I posted from AutoNation and see if dealer will price match. I usually Print the Auto Nation Page and take with me to Ford Local here and they are OK With it and Price Match No Problem
Use at your Own Risk deal for sure
Knowing what we know now Nobody would use dorman
#32
#33
One screen is under the oil cooler for the hpop intake. The ipr and screen is located on top of the hpop pointed to the drivers side head. When the ipr gets loaded full of this **** you will experience a no start due to too low of high pressure oil. The ipr usually goes up to 85% and might only build 100 psi of hpo.
Sent from my leash using IB AutoGroup
#35
Yeah I did the same thing when i did my egr/oil/radiator/water pump. Only problem was if you forget a tool you have to crawl back out of the sharks mouth
#36
#37
#39
What you changing a OC in ?? 6-8 hours or Less
Once you have all the wrench sizes in your Head Probably rock it out Fast
I got the How Down good
Iv had mine apart fairly deep 3 times now
My HPOP was about 10-12 hours Total so I not fast but I got it
I always set something down and end up waisting bunch time finding it LOL
#41
What Material did they make it out of?? Cast or something??
#42
Sweet
It's never just an OC,, cause I don't feel comfortable doin an oil cooler unless I know the system is clean. And if its a late model,,, might as well check for the updated parts,, if its an early model,, I've got my machine shop on point to machine the hpop cover for the tube,, no use in replacing when we can make what we got work. I've got a great hookup with them. No wait,, he drops what he's doin n hooks me up. Last heads I did,, I walked in with them,, n 20 mins later,, out the door done. Love it
