EVERYONE NEEDS TO SEE THIS!!!!! Dorman gasket
Old 01-18-2014, 02:13 AM
lupuseven's Avatar
lupuseven
lupuseven is offline
YouTube Certified Mech
Originally Posted by BLADE35
Well that's Good IPR Clean Sounds Like the typical HPO Leak
That's good to hear!
Well you could just get a Oil Cooler seal kit and reuse the dorman
definitely will be doing that, might have to be at that level anyhow for the HPO leak. Either way I'll pick one up as soon as this job is done... Thurs I think.
So far that's All Iv seen Fail is Gaskets But no Dorman has made it over a YEAR so IDK
I think Dorman Makes Lots of Coolers Like that so I suspect they have that part down OK just Blew the gaskets so far
I put about 30-50k miles a year so we shall see EOT/ECT is always on my SGII screen.
But if you want Take that Price I posted from AutoNation and see if dealer will price match. I usually Print the Auto Nation Page and take with me to Ford Local here and they are OK With it and Price Match No Problem
Use at your Own Risk deal for sure
Knowing what we know now Nobody would use dorman
After I get some tires (Feb), I will do that for sure! Might as well keep one handy, if I don't use it my neighbors might . 4 of the 9 houses on this street have a 6.0
******** charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript">*********>
  #32
Old 01-18-2014, 04:05 AM
97powersmoke's Avatar
97powersmoke
97powersmoke is offline
Sorry I'm a newb to 6.0's but this is the gasket out of the oil cooler correct? And what symptoms would the truck show when this screen and IPR valve screen are plugged like that? And where is that screen located?
  #33
Old 01-18-2014, 06:57 AM
78fordman's Avatar
78fordman
78fordman is offline
One screen is under the oil cooler for the hpop intake. The ipr and screen is located on top of the hpop pointed to the drivers side head. When the ipr gets loaded full of this **** you will experience a no start due to too low of high pressure oil. The ipr usually goes up to 85% and might only build 100 psi of hpo.
Sent from my leash using IB AutoGroup
  #34
Old 01-18-2014, 07:15 AM
cheezit's Avatar
cheezit
cheezit is offline
Ive told you dorman sucks. Just look back at the 4.6l intakes.
  #35
Old 01-18-2014, 10:24 AM
daddykitty's Avatar
daddykitty
daddykitty is offline
Originally Posted by run6.0run
That's Fred Flintstones reverse. Lol. It's hard to see,, but I was standing straight up. Has anyone else worked like that?? Hope I didn't just give away my "secret" lol.
Yeah I did the same thing when i did my egr/oil/radiator/water pump. Only problem was if you forget a tool you have to crawl back out of the sharks mouth
  #36
Old 01-18-2014, 09:19 PM
run6.0run's Avatar
run6.0run
run6.0run is offline
Don't forget I've got Julie right there. I get in there n stay til it's done.
  #37
Old 01-18-2014, 09:48 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
What Happened with Those Cheezit???
Are we Talking 4.6L Intake Gaskets???
  #38
Old 01-18-2014, 09:55 PM
cheezit's Avatar
cheezit
cheezit is offline
No the intake itself. There redesign cracked and leaked worse then the oem, not to mention lowering mpg and cfm rates. Real junk
  #39
Old 01-18-2014, 09:58 PM
BLADE35's Avatar
BLADE35
Sweet
What you changing a OC in ?? 6-8 hours or Less
Once you have all the wrench sizes in your Head Probably rock it out Fast
I got the How Down good
Iv had mine apart fairly deep 3 times now
My HPOP was about 10-12 hours Total so I not fast but I got it
I always set something down and end up waisting bunch time finding it LOL
  #40
Old 01-18-2014, 10:02 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Glad I have OEM on the way!
  #41
Old 01-18-2014, 10:08 PM
BLADE35's Avatar
BLADE35
SOunds like it would end up overfueling to make up for a Lean Condition At the oxy sensor with a Crack
What Material did they make it out of?? Cast or something??
  #42
Old 01-18-2014, 10:27 PM
run6.0run's Avatar
run6.0run
Sweet
It's never just an OC,, cause I don't feel comfortable doin an oil cooler unless I know the system is clean. And if its a late model,,, might as well check for the updated parts,, if its an early model,, I've got my machine shop on point to machine the hpop cover for the tube,, no use in replacing when we can make what we got work. I've got a great hookup with them. No wait,, he drops what he's doin n hooks me up. Last heads I did,, I walked in with them,, n 20 mins later,, out the door done. Love it
  #43
Old 01-18-2014, 10:30 PM
BLADE35's Avatar
BLADE35
Ya I guess you got all the flushing and maybe a few Updates
maybe studs depending on customer
  #44
Old 01-18-2014, 10:38 PM
run6.0run's Avatar
run6.0run
Yeah,,, just got one dropped off tonight for an OC n studs. His hg's are way blown. 20 psi degas at wot in 3 secs,, with a egr delete.
  #45
Old 01-18-2014, 10:56 PM
run6.0run's Avatar
run6.0run
It's freakin amazing the ratio of 6,0's out there running green coolant. It's like 80%. I'm tackling as many as I can.
Quick Reply: EVERYONE NEEDS TO SEE THIS!!!!! Dorman gasket
