Fan Clutch Oscillates
Old Jan 17, 2014 | 09:46 AM
jetdoc's Avatar
jetdoc
Just as the title says....Stone cold engine, fan clutch engages and disengages. Cycling I guess would be a better term. I tried a search, but I must have used the wrong terms or something. Is this normal?
Leaking oil again this am...Somewhere up top this time. I cant win for loosing.
Old Jan 17, 2014 | 09:49 AM
timmyboy76's Avatar
timmyboy76
subscribing.....whether mines, stone cold or warm after running awhile. With temp switch to bi or at feet, you can hear the clutch engaging/disengaging...
Old Jan 17, 2014 | 10:03 AM
BillyBob69's Avatar
BillyBob69
You sure its the fan clutch and not the AC pump clutch? That kicks in for defrost when warming up.
Old Jan 17, 2014 | 12:12 PM
jetdoc's Avatar
jetdoc
Definitely fan clutch. You can hear it and feel the airflow.
Old Jan 17, 2014 | 02:07 PM
The Brad's Avatar
The Brad
Mine has been cycling for a couple of years now. I replaced it with a Napa one and it does the same thing, usually after pulling a grade it partially engages, fully engages, partial,full... This goes on till temps drop enough to disengage it.
Old Jan 17, 2014 | 02:13 PM
jetdoc's Avatar
jetdoc
I can see it happening on a warm engine but this was stone cold this morning. Funny thing is that my coolant temp was cold to the touch but the HPOP reservoir was scalding hot after only a few minutes of running. 138degrees by my el cheapo laser thermometer..
abrarham
Mar 2, 2013 07:10 PM
Dancingchicken
Aug 4, 2010 07:09 PM
JesterPgh
18
Feb 22, 2009 07:40 PM
kc7smo
Jul 12, 2006 12:01 AM
KennethKvittum
Feb 24, 2004 07:22 PM
