whats this noise?
Old Jun 27, 2003 | 11:14 AM
bassaway's Avatar
bassaway
whats this noise?
just wondering if yall have heard this before. I have a standard and when my truck is hot and im idling in neutral and the AC is on, i hear a rattle or vibration noise that sounds like its comming from the tranny/clutch. The noise stops when i either turn the AC off or press in the clutch. any ideas? also, my DPFE sensor went bad about a week ago and got it replaced. should i also check/replace my egr valve and vacuum hoses in the egr system while im at it? thanks
Old Jun 27, 2003 | 11:54 AM
gdoggy's Avatar
gdoggy
whats this noise?
It's probably the heat shield on your exhaust - namely the CAT heat shield.
Old Jun 27, 2003 | 12:36 PM
Ken00's Avatar
Ken00
whats this noise?
No need to replace them if your not getting a CEL or having a problem.
Old Jun 27, 2003 | 12:40 PM
bassaway's Avatar
bassaway
whats this noise?
thanks yall, im guessing that the heat shields are just bolted on?
Old Jun 27, 2003 | 12:47 PM
Ken00's Avatar
Ken00
whats this noise?
Welded on most of the time, get a big hose clamp or several hooked together and use it to secure the shield.
