Dad's Engine
#468
STK was the shop that explained to me that there is no need to have the pistons in hand before the block is bored. So they wont be waiting to get the pistons from Gary to bore his block. I guess he should have had somebody like you machine his block instead of this 40 yr veteran that he took it to. You know, someone that knows what they are talking about.
#470
And that brings up a question I'd been meaning to ask - how often should a torque wrench be checked? Mine has never been checked. So, I'm thinking about buying the http://www.ebay.com/itm/Eastwood-Electronic-Digital-Torque-Adapter-for-3-8-or-1-2-Ratchet-/371001959962?_trksid=p2054897.l4275. It is accurate to within +/- 1%, so should let me dial all of my torque wrenches in.
#471
Brute, that accumulator looks like the old Milodon (?) units. Easy enough to setup as an automatic oiler. Run a line from the oil pressure feed, split it into 2, the first one through a small orifice and check valve to the accumulator, the second through a continuous duty - normally closed (spring return) solenoid, then sum the lines back together at the accumulator. Power the solenoid off a momentary push button via the ignition feed.
That way you just turn the key on, push and hold the button and wait 5 seconds or so before cranking it, kind of like glowing a dieso. One she's running, release the button. The small orifice will allow the recharge of the accumulator without a noticeable effect on the oil flow to the engine. Just don't rev it too hard for a few minutes as the oil level in the sump will be slightly over full until recharge.
#474
And that brings up a question I'd been meaning to ask - how often should a torque wrench be checked? Mine has never been checked. So, I'm thinking about buying the Eastwood Digital Torque Adapter. It is accurate to within +/- 1%, so should let me dial all of my torque wrenches in.
Before the digital one I used a dial type snap-on torque wrench and a female to female adapter I made.
The one I have was about $30 at harbor freight, I know it's hard to trust harbor freight on something like that but so far so good, been a little over a year with it now.
#475
The directions to my torque wrenches say they have to be exercised before you try to torque something with them. It makes sense if you think about it. Sort of like a rifle scope when adjusting them. A tap on the tube with a screwdriver handle makes sure the movement has settled in for the adjustment. Just loading a round and firing it before tapping will produce an inconsistent strike from the one following it in a lot of cases.
#478
Building jet turbines ours were sent out for full calibration every 6 months but we check torqued them on a load cell similar to what you showed before every use. On the airframes it was just the 6 month full calibration, or if dropped /damaged.
For general automotive 12 months would be more than sufficient. If that Eastwood unit comes calibrated then it sound a like a viable unit to use as a master for your self calibration.
#480
