Hi beams flashing
Old Jan 16, 2014 | 08:58 PM
Nate4494's Avatar
Nate4494
Hi beams flashing
I have a 97 f250 powerstroke and I got a plow on it and the high beams started flashing I flipped the switch back and it stopped so got out and played with the plow plug while the high beams on and it didn't help so I unplugged it and the truck lights were doing it I have no idea where to start checking
Old Jan 16, 2014 | 09:32 PM
Jeff Watts's Avatar
Jeff Watts
On that model, pull the headlight switch, and look for signs of heat.
Back then, all the juice for the lights ran through the switch, and it was too much for it. Install relays under the hood, so that the dash switch only trips the relays, and the lights are powered from the batteries.
Also, if you want better light output, you can rewire the high beam switch so that the low beams stay on when you activate the high beams. It makes a noticeable difference.
Also, if you're plowing snow, that means salt. Check your grounds. ALL OF THEM.
Hope this helps.
Old Jan 16, 2014 | 09:34 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hello Nate4494 and welcome to FTE.
Your thread should be posted in the 1987 - 1996 F150 & Larger F-Series Trucks forum (including 1997 Heavy Duty). I'll move it there for you.
88_F0RD
Dec 30, 2016 12:37 PM
88 350 with a 460
Nov 28, 2012 04:52 PM
70torino429
Jul 17, 2010 02:59 PM
'08FX4
Dec 30, 2009 01:38 PM
Weezman
1978 - 1996 Big Bronco
Sep 9, 2008 05:04 PM
