88' F350 RestoMod info gathering
Oh you have one of the infamous stretched frames?
I can get one the same size as what came on the truck for about $250 but I question if that is enough for the loads this thing sees... The original one became FUBAR in a 5 car pile up.
Oh and this is for ATF not engine oil.
I've done quite a bit of towing with mine, and I've never had an issue with the stock trans cooler. I installed a trans temp gauge just to be on the safe side though.
As far as the D60, I can't really offer any help on that...
Is it visible where they stretched the frame?
Mine weighs 5100... so that's 1000 off I think. Although my non centurion F350 is "5400" so maybe it was ford doing that?
I no longer have the centurion cooler I have a smaller one.
I hear good things about the D60...
I would have done at least an angle cut, if not a Z cut. But, it's held up pretty well for this long. Last year, I plated the outside of the frame, from just after the Centurion welds, to just before the front spring hanger. The bed flex on this thing was NOT confidence inspiring at all, and any trailer with a tongue weight of more than 200 lb. would flex the bed vertically. It's much better now, with the plates I added.
My trans cooler is the Ford factory cooler, though I re-routed the lines to avoid having trans fluid go through the radiator before the aux cooler.
Yep, very visible. I thought I had a picture of it on Photobucket, but I don't. It's not the worst fab job in the world, but it's not the way I would've done it. It's basically a straight cut, with a channel welded in to lengthen the frame. There's fish plates and an angle welded in on the back side too.
The only pickups that were cut and stretched were the 1/2 tons. Since yours was available as a CC from the factory, you're correct about upgrades.
I believe they cut a stretched a few 1 ton CC's to make six door cabs.
Anyone know where to get this trim? http://thumbs2.ebaystatic.com/d/l225...-Sc5_L3NFw.jpg
Hey guys,
Looking at some parts off an 89' F250 to do a 4x4 conversion. The F250 has a 5spd. Can I take the tcase off the 5spd(probably a zf5) and put it on my c6? My c6 has had work done to it to make it a good towing setup. Would the F250 have a dana 60 front? Do I have to do a front leaf conversion?
I figured while doing a frame off is a better time than ever for this.
Not a factory coil setup. Factory F350s will have the Dana 60 you're looking for, and were leaf spring only. Of course, if you're willing to fab stuff up, you could swap in a coil sprung D60 out of a Dodge, along with the trailing arms and whatever else Dodge uses to keep the axle in place.
#30
