When do you guys plug em in
Old Jan 14, 2014 | 05:21 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
With temps getting a little chilly and going away ice fishing next week I'm just wondering when you guys start plugging in your trucks. I've only encounter a handful of days just below the freezing mark and the beast always barks to life, let's out a shot of smoke and runs great.
Old Jan 14, 2014 | 05:25 PM
ReBilld's Avatar
ReBilld
I usually plug mine in when it starts getting below 40* at night. I know you don't have to but the it seems to me that it would be easier on all the engine components starting a warm engine. I do want to get a timer to put mine on though so it's not sitting there all night sucking electricity
Old Jan 14, 2014 | 05:52 PM
MOOSE_MACHINE
Haha. All the times I thought of a timer with the old moose machine(89 F-350 w/ 7.3). Never got around to it though. I read somewhere that cold starts are pretty hard on these things. Thanks for the reply
Old Jan 14, 2014 | 05:59 PM
ReBilld's Avatar
ReBilld
Tyler put a timer on his about a week ago. I'm like you though, I've thought about it several times, but haven't done it yet. The block heaters use quite a bit of power.
Old Jan 14, 2014 | 06:04 PM
martin72's Avatar
martin72
When I drove everyday I plugged my in if it was below 40. I am like Bill I think it easier on the whole motor.
Old Jan 14, 2014 | 06:17 PM
fordman67's Avatar
fordman67
I had a timer and had it 4hrs warming before going to start it.
Old Jan 14, 2014 | 08:37 PM
madpogue's Avatar
madpogue
Block heater draws 1000W. So whatever your per-kWh rate is on your bill, that's exactly how much it costs to run per hour. Typically it's around 15 cents / hour. So if you use a timer, for every six hours you DON'T run it, it saves a buck. Pays for the timer pretty quick.
Also, turn the HVAC control to Defrost when you park it. The coolant circulates a bit as it's heated, so when you light it up, it defrosts your windshield faster.
Old Jan 14, 2014 | 08:55 PM
redman84's Avatar
redman84
I normally set it for 3 hrs prior to estimated start up time. I really only use it when it's predicted to be below freezing and I'm going to work or hunting. Warm air from the word go sure is nice.
Old Jan 14, 2014 | 11:17 PM
joshjen2000's Avatar
joshjen2000
I plug mine in below 35 or 40. I will be purchasing a timer for sure!
Old Jan 15, 2014 | 01:20 AM
IDMooseMan's Avatar
IDMooseMan
I've used a timer previously. I went the "cheap" route. Don't remember where I bought it, but I'll do a bit more research the next timer I purchase a timer. My old timer has fallen apart. Also, it started tripping the circuit breaker towards the end of its life.
Those of you currently using a timer, would you post the brand and model number you're using? Either I'm getting some bad timers or I'm using the wrong brand.
Old Jan 15, 2014 | 06:46 AM
Hussler's Avatar
Hussler
Got mine from ACE hardware many years ago and it's still working. A few weeks ago I was at Home Depot and they had some for about $15, but don't know the quality. It says right on it for vehicle block heaters. This year I have it set for 2.5 hours (3 am - 5:30 am). Anything more than 3 hours seems to be a waste. Pays for itself pretty quick.
Old Jan 15, 2014 | 07:25 AM
MOOSE_MACHINE
Originally Posted by IDMooseMan
I've used a timer previously. I went the "cheap" route. Don't remember where I bought it, but I'll do a bit more research the next timer I purchase a timer. My old timer has fallen apart. Also, it started tripping the circuit breaker towards the end of its life. Those of you currently using a timer, would you post the brand and model number you're using? Either I'm getting some bad timers or I'm using the wrong brand.
Most of those cheap timers ar exactly that. Cheap. I have always found that they just don't stand up to heavier loads
Old Jan 15, 2014 | 07:37 AM
TyBragg's Avatar
TyBragg
I haven't had my timer on long, but so far I like it! I set it to come on at 4:30, so that gives me about 3 hours warm up time. I also set my timer to pass power from 4:30 AM-4:30 PM because there are times when I haven't planned on taking my truck somewhere but then find out I need it during the day, so i'll go plug it in, even if it's only for 30 minutes. I didn't want to have to run in my building and reset the timer every time I do that. I bought my timer at Tractor Supply - they had them on sale right after Christmas.
Speaking of timers - I put my chicken water heater on a timer too! I figured there was no reason to have it pulling power 24 hrs/day, so I set it up to run for 2 hours, then off for 2 hours, so on. Saves me 1/2 the power it was using and works just fine! My 5 year old son asked me while I was setting it up "Daddy, why do you like timers so much?" LOL!
Old Jan 15, 2014 | 07:59 AM
madpogue's Avatar
madpogue
DO NOT get this one: Woods 13571 Indoor and Outdoor 24-Hour Mechanical Timers (2-Pack) - Smarthome . The outdoor-grade one is cr@p. First one I got, the clock drive hung up on the little on-off tabs and stopped keeping time almost right away. Exchanged at the store, new one lasted about a year and now it's doing the same thing. I don't even have it outdoors (have an extension cord going from inside to outside). Didn't have any trouble with the electrical load, it was just the mechanical time-keeping that epic failed.
This one:
Woods 59204 All Weather Outdoor Timer with Rain Tight Case, Repeats Daily with 3-Prong Plug - Amazon.com Woods 59204 All Weather Outdoor Timer with Rain Tight Case, Repeats Daily with 3-Prong Plug - Amazon.com
has held up so far.
Old Jan 15, 2014 | 09:40 AM
TyBragg's Avatar
TyBragg
I'm with Bill though on the temp - as soon as it gets 40* or below, I plug it in. I figure it's got to be better for it than not. I know guys who never plug theirs in until it's 0*, but I can tell a difference in cold starting at 40* when it's plugged it in vs. when it's not, so that tells me that i need to plug it in when I can.
