How does the alt. gauge work?
Old Jan 14, 2014 | 04:20 PM
ColtonMullis's Avatar
ColtonMullis
I was just looking at the gauge cluster and i noticed that my alt gauge has never moved. I don't think i have every seen a dentside were this gauge moves. Does it move when the alternator quits working? Thinking about replacing it with a volt meter.
Old Jan 14, 2014 | 04:37 PM
spikinfool05's Avatar
spikinfool05
it doesnt work not even from the factory.
Old Jan 14, 2014 | 04:40 PM
ColtonMullis
why would you put a gauge in that doesn't work. lol. Do they make aftermarket volt meters that fit in it's place?
Old Jan 14, 2014 | 04:44 PM
spikinfool05
its more of a ammeter gauge than a volt meter. there is a company that takes the ameter gauge and makes it work like a volt meter gauge. here is the link Rocketman's Classic Cougar Innovations i have not dealt with the company personally but i have heard good things here about them.
Old Jan 14, 2014 | 04:55 PM
fmc400's Avatar
fmc400
MSEE
The factory ammeter is called a shunt ammeter. Most of the current to or from the battery flows through the main feed. The factory ammeter is in parallel with the main feed. A small amount of current, proportional to the current through the main feed, flows through the ammeter. Current through the ammeter causes needle deflection.
This method results in very, very coarse resolution, so much so that the factory ammeter is useless. A voltmeter is a much more effective tool. Aftermarket voltmeters are easily accessible. There is a company that makes retrofit voltmeters to take the place of the factory ammeter, with an original appearance. I believe that's the one in spikinfool05's link. I prefer the larger swing and finer step size of an aftermarket voltmeter.
Old Jan 14, 2014 | 04:59 PM
spikinfool05
thanks fmc knew you would be around.
Old Jan 14, 2014 | 05:21 PM
ColtonMullis
If i bought one of those would i have to do any extra wiring?
Old Jan 14, 2014 | 05:24 PM
turbohunter's Avatar
turbohunter
Here's the one I used.
Just scroll down to F series replacement.
Very useful.
Old Jan 14, 2014 | 05:25 PM
fmc400's Avatar
fmc400
MSEE
Anything electrical has to be wired up, of course. For any voltmeter, you must run the "power" lead to a switched 12-volt source (easily available) as well as ground (easily available). Most dash-mount voltmeters also have provisions for dash lighting (again, easily available).
The retrofit voltmeter on the website is NOT a drop-in replacement, if that's what you were asking. They are two completely different types of circuits. Part of the printed circuit on the back of the cluster needs to be masked off to allow the installation of the retrofit voltmeter, with additional wiring tucked behind the gauge.
Old Jan 14, 2014 | 07:47 PM
ColtonMullis
I'll proably just get the dash mount along with the vacuum and tac gauges I'll be putting in. Where do you guys mount you're gauges. i was thinking at the bottom of the dash or along side the cab corner.
Old Jan 15, 2014 | 05:00 AM
Ordnance's Avatar
Ordnance
I guess I'm the lucky one. both the cluster that was in my truck originally, and the one in it now had working ammeters. I assume so at least, when i blip the accelerator, it goes toward the "C"
Old Jan 15, 2014 | 08:08 AM
fmc400's Avatar
fmc400
MSEE
Here are my gauges, along with my homemade tach:
Old Jan 15, 2014 | 08:57 AM
460me's Avatar
460me
Put mine here:
Old Jan 15, 2014 | 11:38 AM
dustyroad's Avatar
dustyroad
Originally Posted by 460me
Put mine here:
Ever smack that with your knee getting in? I was going to put mine there and figured it would make a nice knee banger after looking at it some.
I have a lift on mine as well which might make a difference with getting in and out.
Old Jan 15, 2014 | 11:56 AM
460me's Avatar
460me
Nope. Never hit the gauges.
