I drove my truck for the first time today to move it from the garage bay it was sharing with a '63 Impala to an empty one 10 feet away.
It was great to see the truck moving under it's own power, but my arms feel like I spent eight hours in the gym! If manual steering isn't bad enough, the truck needs new king pins so the effort required to steer it was at least doubled.
I know I need to replace the king pins (and probably everything else in the front end), so my question is this: how much of an improvement am I going to see with new king pins, etc...? Or should I start to consider swapping out the front end to one with power steering?
I'm in the very early stages of restoration and can still go either stock or custom (haven't decided yet)
If I swap out the front end, does anyone know what newer front ends would swap with a '47 Ford 1 ton pickup?
It'll tighten up the steering, but it'll still be kind of tough, especially if you add radial tires and go any wider. You could add a steering box out of a GM car and add the GM pump to get power steering. That's what I'm doing on my '46 1/2 ton. I bought a good box and pump, plus an adapter for the box to frame for $65 from my local paper. BTW, nice site you have there. I really like the pictures of the truck.s I'm glad to see that rust/blue 1 ton pickup I saw on eBay go to a good home.
I think the pump and box on mine is from an early '70's GM, usally an A-body car. I think in the latwe '70's GM went to metric boxes, so look for something from th eearly 70's. Then I'd match the pump to the year and model the box came from. There are also quick ratio boxes, but I think those came on the hi performance models of the A-bodies. The adaptor will have to be made...We modified a passenger car one to work. They are different from the trucks.
Do I understand that the adapter is only to mount the box to the frame? If that's the case we should be able to fabricate something with the welder and torches.
Yeah, the adaptor is to mount the box to the frame. So if you are handy with a welder, then you could easily make one up. As for mounting the pump to the motor, that'll depend on the motor you use.
