Sponsored by: Real Truck
help
Old Jan 12, 2014 | 09:14 PM
00f350superduty's Avatar
00f350superduty
help
ok guys fairly new to the world of owning a ford!! I have a 2000 f350 v10 ext cab 8 ft bed 4wd,i replaced all 10 plugs all 10 coils at 40 mph the truck violently shakes an vibrates read on a few things that could be crack cylinder or bad pistons,i did a test on it an says low compression in 2 cylinders 1&2 what can I do an what is the best option for me as I just got the truck not even a month ago thanks in advanced-pat
Old Jan 12, 2014 | 09:35 PM
redford's Avatar
redford
FTE Leadership Emeritus
Low compression on 1 and 2? If you really mean 2 adjacent cylinders, that is usually an indication of a blown head gasket.
Old Jan 12, 2014 | 09:40 PM
00f350superduty
well if it was a headgasket wouldn't I notice anti freeze in my oil? I did a oil change the other day an no coolant was mixed AT ALL now I do notice when I start the truck the exhaust literally bounces up an down an has a slight skip but not sure why the most noticeable issue is the vibration at 40,I have no loss in oil pressure or anything stays normal temperature an don't overheat!!
Old Jan 13, 2014 | 08:27 AM
tjc transport's Avatar
tjc transport
i ain't rite
not really. if the head gasket blows between the two adjacent cylinders in the middle of the gasket, it will just pass compression between the two cylinders.
easiest way to tell is to do a compression test. if #1 and #2 cylinders have the same compression numbers it points to a blown gasket.
truck crazy man
17
Feb 6, 2014 07:50 PM
Bill's2000X
Modular V10 (6.8l)
Oct 3, 2010 01:40 PM
gwp36530
Apr 25, 2004 01:02 AM
sixx pak
Jan 31, 2003 02:18 PM
unioncreek
Dec 29, 2001 07:24 PM
