86 surges while coasting downhill
Old Jan 12, 2014 | 08:19 PM
shawn_gumby1's Avatar
shawn_gumby1
So i have an 86 F150 4X4 with a 302 and AOD auto. As stated while coasting it surges. To go a little more in depth it started about 2 yrs ago and just recently got WAY WORSE!!!!!! If i am say doing 55 and go down a hill and let off the throttle it would jerk and start rapidly slowing down. Im, a experianced diesel mechanic and it felt just like i was using the engine brake. As soon as i touched the accelerator it would jerk again and coast normal. But recently the jerking has gotten MUCH MORE VIOLENT and now it does it all the time when I let off. It doesnt stall when i Stop and and getting like 9mpg now opposed to the 13mpg i use to get.The tranny has a shift kit and upshifts and downshifts fine through all gears. The fluid is full, not burnt, the trans is not slipping under acceleration. But its doing this so violently now i can no longer safely drive it. This old girl is my baby and any help would be greatly appreciated.
1. could it be the torque converter locking up under coast doing this ?
shawn_gumby is online now Report Post
Old Jan 13, 2014 | 06:51 AM
SSellers's Avatar
SSellers
Do you see any difference in the situation between having the shifter in drive as opposed to overdrive?
Also check the transmission throttle valve cable at the throttle body butterflies....with engine off pull it out all the way and see if it returns smoothly.
Old Jan 13, 2014 | 06:31 PM
Franklin2's Avatar
Franklin2
Sounds like your throttle stop screw is off, or there may be something wrong with the tps. I would pull the codes from the computer before I did anything else.
If you do not have any codes, I would get it idling and then pull the plug off the idle air control valve. The engine should run really slow, barely turning over. If it quits right away turn the idle stop screw in some. If it's idling normally, then back the stop screw out till the engine is barely running.
If the computer sees the rpms are high, and the tps is in the idle position, it assumes you are coasting and turns the fuel off to the injectors till the rpms get to a certain value, and then you will feel a "bump" as the computer turns the fuel injectors back on. As you push on the gas pedal you are taking the throttle out of the idle position, and the computer will turn the injectors back on.
Old Jan 13, 2014 | 07:52 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Also, you could have a rear axle in need of attention. The 8.8" isn't as durable as the old 9" was. What you are feeling could be due to worn pinion bearings/spider gears/axle splines. Any one, or a combo of more than one. They're all prone to wearing out.
I'd hate to see you throw money at the trans, and the problem be elsewhere......
Old Jan 14, 2014 | 08:00 AM
shawn_gumby1
OK. Thanks for the replies. To start off my odb hookup has never worked. I've tried multiple computers and always have gotten "computer will not respond". I've even tried a new computer and got the same thing so I can't pull codes. It doesn't matter what gear the trans is in or what gear I have the shifter in. It does it every time I coast. I pulled the tcc cable and it staps back with no drag. I will try to pull the IAC off when I get home. Thank you guys so much for helping
Old Jan 14, 2014 | 08:47 PM
ctubutis's Avatar
ctubutis
If it's happening even with the transmission in neutral (effectively disconnected from the engine) this is another good reason to investigate your rear differential & drivetrain.
johnfl
General Automotive Discussion
Nov 5, 2023 09:39 PM
HalR
Jun 21, 2011 09:22 PM
Adrenaline4X4
1978 - 1996 Big Bronco
Feb 28, 2010 04:35 PM
SMiddleton
Jan 16, 2007 12:19 AM
mjb1962
Feb 23, 2001 11:29 PM
