Have you tried starting it with a 12 volt system?.....negative to negative, positive to positive
Ed
near Philadelphia
I have not tried 12 volt but will if that won't do any damage to anything.
I remember when Floyd arrived on the delivery truck the battery was dead and the driver used a 12 volt jump starter and everything seemed to work thereafter.
When you hear a whirring sound when you attempt to crank it is usually a starter spinning but the bendix not engaging the flywheel. Causes for this that I have seen are, low or bad battery, loose or dirty connections, bendix that is stuck on starter shaft, bad starter. Since you say the lights start out bright then go dim or out when you attempt to crank I would be looking at connections or a bad battery or a bad starter. I had a battery just last week that showed good voltage but would not crank the engine. Turned out to be a bad cell in battery. Cheapest things to check are connections and battery, a auto parts store can load test if for you. If both are OK I think you are looking at a starter problem.
I probably used the wrong terminology. The only sound that happens comes from the solenoid. I was standing close to it while wife hit the start button and clearly there was a sound coming only from the solenoid. When she pushed the button I could hear a sound like a relay opening then the sound that I described as whirring.
I tried jumping across the poles on the solenoid and did get a strong spark on the battery side but it did not inspire any starter activity.
If you jumped across the large terminals on the solenoid and the starter still did not turn then the problem is not the solenoid. Shorting the large terminals bypasses the solenoid. You must always use a large gauge wire or heavy screwdriver to do this as the full load of the starter goes through whatever you use.
It's a good idea to take pics when taking things apart, especially if the parts aren't going to be reinstalled the same day. You should not rely on memory only.
Installing batteries backwards is a common problem. People should pay attention to where the terminals are located.
Another common problem is buying the wrong battery. GM & ChryCo batteries have the terminals reversed.
People buy without paying attention to how their old battery is configured, then unknowingly hook the cables up bassackwards. Then they wonder why the amp gauge needle shows discharge.
One more thing to check. You didn't charge the battery in reverse polarity did you? I have seen this done a couple times, the positive terminal is now negative and vice verse. Doing so will drive you crazy with troubleshooting.
Mike, when I charged the battery I hooked the charger positive cable to positive post, negative to negative post. The voltmeter read 7.8 volts when charged.
I then installed the battery with the positive cable (from the positive post) to the transmission bolt (where it was when Floyd arrived). The negative cable from the negative post traces to tone side of the solenoid.
When I jumped across the solenoid terminals I used a jumper cable. It appears the jumper cable is thinner than the cable coming from the battery to the solenoid. The jumper cable did elicit a strong spark but no starter action. Just so I miss nothing in my explanation, the ignition was turned on when I jumped the solenoid poles.
I have dutifully taken pictures as I have disassembled Floyd but never knew about the positive ground system so paid no attention to the way the battery was connected.
Bill, would you please give me a bit more explanation regarding the appropriate battery, i.e. the Fomoco vs. GM? The battery purchased is an Interstate 6 volt and when I bought it I made no specification as to the vehicle I was going to put it into.
That description would lead me to the starter. It has been sitting for some time. I would try tapping on the starter with a hammer. You might get lucky. Otherwise I would pull it and bench test.
I am in agreement with Pete, at this point it looks as though you have a starter problem.
