Hey... I've been looking all over the internet trying to see where I can find a rebuild kit for my 1967 Ford F100 3spd. W/O.D. steering column. I can't seem to find a kit and if I order the parts I need I want to make sure I buy everything at once. Can anyone please help me?
LMC doesn't have everything I need. Carolina Classics has more, much more. I know I need: Shift tube, upper and lower bearings, 1 plastic thrust washer (for the linkage,) 1 upper bearings leave, 1 lower bearing retainer, and 1 lower bearing seat. Don't know if I need anything else? I just want to order everything I need at once so I don't have to keep paying shipping for having to re-order. Thanks again
Call Rick Monday at Carolina Classics. I am not aware that there is any difference in a truck column with or without OD. Number Dummy should have any part numbers.
PARTS NECESSARY FOR REBUILDING
SOURCES: Macs Auto Parts, EarlyFord.com, Dennis-Carpenter.com, CarolinaClassics.com
Column Shift Arm Spacer
(Fig. 8 above, orange arrow) '65-'71 C9TZ-7336-A $3.95 ea
'72-'79 D2TZ-7336-A $3.95 ea.
Column Gear Shift Arm Thrust Washers
(Fig. 8 above, yellow arrows) (2 per truck)
1965-79 F100/250, Bronco
C5TZ-7D363-B
$2.00 ea.
Gear Shift Selector Arm Bushing & Insulator Kit
(located on the ends of each of the two shifter arms, as seen in Fig. 8)
'65-'72 F100/250
C5TZ-7343-A
$16.00 kit
Shift Tube
'61-'77
$50 - $60.00
Upper and Lower column bearings '64-'72 $6.00
Upper bearing sleeve '53-'77 B1AZ-3518-A $4.50
Shift collar for standard shift '61-'77 $38.00
Steering column tube flange
(picture courtesy of Macs Auto Parts) '66-'72 C5DZ-3511-A $29.95
(pictures courtesy of CarolinaClassics.com unless otherwise noted).
CarolinaClassics also has a complete column rebuilding service.
I've been unable to locate a source for the plastic sleeve located at the base of the shifter tube (as seen in Fig. 10). In fact, it doesn't even show up on the exploded-view diagrams above. If you have any info on this piece, please e-mail me.
Also try www.dennis-carpenter.com. Check your shift flange (the housing shift lever mounts in) for cracks in the bridge from it's outer part to inner part. Also check your rubber steering coupler at the bottom of the steering column. AKA rag joint.
What I mentioned is what I need, don't know about retaining clips or anything like that. Please if anyone has any info on parts needed besides what I listed let me know.
WESLEY OBSOLETE PARTS in Liberty KY has 62 = 606-787-5293.
----------------------------------------------------------------------------- C5TZ-7343-A .. Manual Control Selector Lever Bushing & Insulator Kit / Obsolete
TISON has 3.
GREEN SALES has 19.
CARPENTER has 1,954 (!).
------------------------------- C5TZ-7D363-A .. Thrust Washer-Manual Control Selector Lever / Obsolete
KAMA OBSOLETE PARTS in East Bethel MN has 5 = 763-434-0123.
I've typed all the numbers/sources...except one, waiting for the OP to tell me M/S or P/S inre to 3D681lower bearing retainer
I believe ya, can't see it. Both the T1 slides I got are SOOO scratched up. I came up with the C5TZ prefix on the line I kinda could read out of the OL' memory banks.
I can send you my C/D catalog so you can burn a copy.
I have a new original never used 1965/72 Ford Passenger Car loose-leaf catalog. You can have it for free.
Member of SoCal Galaxies bought it, put it into a gazillion stationary store type 3 ring binders, then sold the car.
