Changing Fuel Filter???
Old Jun 26, 2003 | 08:09 PM
rebelbob's Avatar
rebelbob
I THINK my fuel filter needs to be changed to a new one but ive never changed one before.i have a 95 250.when i take the two hoses off each end of the fuel filter will gas come pouring out?thanks
Old Jun 26, 2003 | 08:36 PM
Chas1234's Avatar
Chas1234
Yes gas will come pouring out so get that bucket ready !
Make sure that the fuel system is relived of pressure by letting the truck sit for a few hours or over night before you remove the filter or you are going to get soaked with gasoline!
Old Jun 28, 2003 | 06:43 PM
03f150man's Avatar
03f150man
relieve the fuel pressure by locating the schraeder valve. Looks like a tire valve. On 97 4.6, the valve is near the fuel rail, passenger side, about 3 spark plugs from the front of the truck. put a rag under the valve to catch the release. Buy a fuel filter release tool. You can get them in plastic or metal. Metal ones are what you want, cost only about $6. Wear safety glasses when you unhook the fuel filter. obviously, no smoking, etc. good luck. i havent changed fuel filter on a f250 but probably same setup as my 97.
Old Jun 28, 2003 | 09:13 PM
StrangeRanger's Avatar
StrangeRanger
Or you can pull the fuse to the fuel pump relay and crank the engine. Fuel pressure relieved. Open the gas cap. too.
Old Jun 28, 2003 | 10:17 PM
bobcf's Avatar
bobcf
yes you get fule, but it is not gallons, just what the lines hold and the filter
bob
