hard starting when hot, check engine light.
Old Jun 10, 2002 | 05:58 AM
Justin89's Avatar
Justin89
ok, i have an 89 f-150, 5.0 AOD, i fixed the intake gasket and leaking valve cover gasket. the truck idles at about 800-900rpm now instead of 1400, the truck has had a problem for awhile with a hard starting when hot, if you drive it and then shut it off and try to start it 2 or 3 mins later it turns over slowly. the check engine light is new, turns on after you drive it about 20miles, then shut the truck down and re-start it, the light goes off. any ideas about the starting? i'm gettin the light checked out at work(i work for a car dealership). thanks in advance.
Old Jun 10, 2002 | 08:29 AM
ddaa's Avatar
ddaa
