DUALLY RIM SIZE
Old Jan 8, 2014 | 09:46 PM
5X5's Avatar
5X5
DUALLY RIM SIZE
I am looking at a F250 1988 dually. It is on jack stands, with no wheels, as a project truck. Any idea was size rims it takes? Are there factory Ford aluminum rims that were made to fit this combo? Thanks
Old Jan 8, 2014 | 10:34 PM
Diesel_Brad's Avatar
Diesel_Brad
16x6 and YES the Alcoas that ford offered will bolt on
Old Jan 9, 2014 | 09:27 AM
5X5's Avatar
5X5
I FOUND SEVERAL FORD Alcoa WHEELS BUT THEY ARE ALL 7" RIMS. WILL THAT AFFECT THE REAR DUALLY SET UP? I CAN RUN THE FACTORY STEEL WHEELS FOR THE INSIDE RIMS.
Old Jan 9, 2014 | 10:00 AM
Diesel_Brad
Factory for Alcoa wheels that are 7" wide are for Single wheel applications, NOT dual.
And YES you have to run the steel inside wheels with a dually, there is not enough stud or hub to run dual aluminum wheels
Old Jan 9, 2014 | 11:26 AM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Learn something new every day on this site. I did not know you had to run steel wheels inside on a dually. One of the upgrades I wanted to do to mine was get the Alcoa wheels, and I just assumed I would need to buy 6 of them. Good to know I don't.
Jim
Old Jan 9, 2014 | 06:48 PM
Diesel_Brad
Jim
I am running 6 aluminum wheels on my truck but it is not stock
The inner wheel goes on and a 2" billet steel spacer goes on next(2") 8 lug nuts are installed holding the inner wheel and spacer on.
Then the spacer has 8 new suds to bolt the outer wheel to it.
I needed to run the 2" spacer because I am running such wide tires
Pics of my inner wheel and spacer
Also not the new "lip" on the spacer to center the outer wheel
BadDogKuzz
28
Nov 28, 2013 08:21 AM
Mad_max
May 31, 2012 12:39 PM
Trm-12
Jan 23, 2011 10:39 AM
daf_62
Jan 3, 2002 11:08 PM
