Wheel size?
Old Jun 26, 2003 | 04:29 PM
mike357's Avatar
mike357
Wheel size?
I have a 1982 F250 4X4 with what should be stock wheels. What size wheels are these, and is it a split rim (what is a split rim) and if it is a split rim a friend at work told me some garages can not install tires on them. I want to purchase a wheel and tire since the spare is missing.
Old Jun 26, 2003 | 10:54 PM
bigpaul's Avatar
bigpaul
Wheel size?
It cuold be 15#8 or it could be 16#8, some 82 trucks had the small bolt pattern wheel or big bolt pattern . How many lug bolts does it have ?If it has 8 lugs most likely it is a16'wheel.
Old Jun 27, 2003 | 12:50 AM
Hillbillywagon's Avatar
Hillbillywagon
Wheel size?
82 should be if I remember correctly a 8 lug 16.5x8.75 wheel. I dont belive that they were split rim.
Old Jun 28, 2003 | 01:20 AM
Txquadhunter24's Avatar
Txquadhunter24
Wheel size?
on the F250's they where 8 lug 16x7.5 unless it's got 16.5 rims. Check the numbers on the side of the tire to find out if there 16" or 16.5". Most all stock 16" rims are 7.5" wide, The 16.5" where usually 8.75" wide. no they wouldn't be a split rim. They where found on your F500 and such trucks. Whichis a bigger bolt pattern then a f250 or F350. Split rims will have (what looks like a snap ring) on the outter bead of the rim.
