Help, no brake pressure!
Old Jan 7, 2014 | 09:22 AM
tkisling's Avatar
tkisling
When I started my truck up yesterday morning I noticed that my brake pedal went to the floor and felt like it had no pressure. I have to press the brake pedal to the floor to stop and it tends to lock up then. I checked under the truck and did not see any leaks or dripping. I checked the master cylinder level and it appeared to be about a half inch below the top. I have always had perfectly working brakes since I bought the truck last year. Where do I start troubleshooting? It's been in the negative teens and twenties here in WI the past few days and I am wondering if that is to blame?
Old Jan 7, 2014 | 12:42 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Extreme cold can cause old-ish master cyls to fail. It may work ok again once the temp gets back to *somewhat* normal, but I would advise getting a replacement anyways.
Old Jan 7, 2014 | 12:45 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
first off, start with basics. Are you low on fluid? if so, top it off, and pump it, looking for leaks. Blown lines are common this time of year.
After passing the visible leak test, then its time to pull the wheels and look at the calipers, wheel cylinders, and hoses. Still no leaks?
check where the master cylinder bolts to the brake booster. is there a stream of fluid running down under it?
that should get you started.
Old Jan 7, 2014 | 12:59 PM
maytag906's Avatar
maytag906
I'm betting on a broken line somewhere.
Old Jan 7, 2014 | 01:15 PM
tkisling's Avatar
tkisling
No visible leaks around the master cylinder. I am having the shop next door to my work take a look at it this afternoon. Hopefully they can give me an idea on what it is, I am no stranger to replacing master cylinders or fixing brake lines.
Old Jan 7, 2014 | 04:02 PM
Bootlegger's Deluxe
good deal. my bet is that if its no obviously broken line or anything, then it's the rear wheel cylinders.
Old Jan 7, 2014 | 04:52 PM
Franklin2's Avatar
Franklin2
Broken lines or other problems like leaking wheel cylinders and hoses will cause a loss of fluid. He said it was only a 1/2inch below the top of the master cylinder when he checked the level.
Old Jan 7, 2014 | 05:00 PM
tkisling's Avatar
tkisling
The shop didn't get a chance to look at it today. I just went under the truck myself when I got home with a shop light and didn't notice any wet spots on the lines or the connections. The pressure seems intermittent, it will build sometimes but then go down, the brake light on the dash goes on and off too. I will have a partner push the padal with the truck running and see if find any squirts underneath. Would it be a bad idea to give the brakes a basic bleeding with the screws and see if that helps??
Old Jan 7, 2014 | 05:03 PM
Franklin2's Avatar
Franklin2
Old Jan 7, 2014 | 05:52 PM
tkisling's Avatar
tkisling
I had my brother cycle the pedal with the truck on while I went around underneath the truck with a light. I didn't spot any leaks or squirting fluid. The only likely suspect in my opinion is the master cylinder.
Old Jan 8, 2014 | 01:01 PM
tkisling's Avatar
tkisling
I drove the truck to work today and still had no brake pressure intermittently with no leaks or loss of fluid, I bought a new master cylinder from Oreilly's and will hopefully be able to fix this this weekend.
Old Jan 9, 2014 | 09:10 PM
TJ's Dad's Avatar
TJ's Dad
Couldn't help but ask follow-up to this thread. I too am in Wisconsin, have suddenly developed same issue, although I do not get the brake light on the dash. I also have no leaks and am not losing fluid at all. Master cylinder has not gone down at all. This happened once about two weeks ago on a very cold morning, but pedal pressure came back before I got to work. Today it is soft pedal again but can "pump" them up with 2 or 3 pumps. Is this issue just the master cylinder or is this the power booster or both. This is an 85 F150 so at 29 years old... Any help would be greatly appreciated.
Old Jan 9, 2014 | 09:56 PM
Gary Lewis's Avatar
Gary Lewis
Brake fluid is hygroscopic, meaning it absorbs moisture. But, if enough moisture froze and held a check valve in the master cylinder open it could cause loss of pressure.
Amish65F100
38
May 25, 2017 11:10 AM
aedinius
Oct 18, 2013 07:47 AM
Brent021
Jul 12, 2010 10:01 PM
flyhound
Jan 21, 2007 02:42 PM
msfprobass
Mar 6, 2003 06:35 PM
