Sponsored by: Real Truck
2002 f350 hid problems
Old Jan 6, 2014 | 07:12 PM
Cranesf350's Avatar
Cranesf350
We'll I installed hid hi/low hids and they work
Great also went to install hids in my fog lights
We'll got them hooked up and they came on but
Then turned off right away and noticed the fuse
Number 43 is blown put new 10amp in and they
Turned on then blew the fuse should I up the fuse?
Any help would be nice thanks for your time.
Old Jan 6, 2014 | 07:44 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hi Cranesf350 and welcome to FTE.
When you installed your new HID lights, did you just use the stock wiring?
Old Jan 6, 2014 | 07:49 PM
Cranesf350's Avatar
Cranesf350
Yea I did use all the stock
Old Jan 6, 2014 | 07:53 PM
redford's Avatar
redford
As you have found out, that won't work. HID lights take a lot more power.
The stock wiring and switched won't handle the power, which is why the fuse is popping. You need to install a relay, controlled by the stock light switch, and heavier wiring to deliver higher amperage to the new lights.
Old Jan 6, 2014 | 07:59 PM
Cranesf350's Avatar
Cranesf350
Yeah that's what I kinda thought off but a buddy
At my work has the same kit and same truck and
His fog lights work fine that's why I was wondering.
And do you know if #43 is a fuse for the fog lights?
Danjo523
Jan 17, 2017 08:29 PM
Jesse73iditurbo
May 11, 2016 08:53 PM
NewEnglander
1978 - 1996 Big Bronco
Apr 4, 2012 03:31 PM
shotme
Sep 30, 2010 08:43 PM
powerstroker02
Electrical Systems/Wiring
Oct 22, 2009 12:21 AM
