Connecting tranny cooling lines to aluminum radiators
I was thinking about the steel lines to aluminum connections on aluminum radiators....should I have a brass connector between the two?
Or is it normal practice to connect them directly. My concern is the aluminum being softer than steel and wear-n-tear on the radiator connector.
Input please? Thanks!
I'm running a 1/8npt to AN6 adapter in the rad end, this is blue anodised aluminium. I'm then running AN6 braided line to the trans. No steel in it anywhere apart from the braid. But I'm seriously thinking of doing away with the integrated cooler in the rad and having a standalone cooler on the front or under the truck somewhere....
We just used AeroQuip steel fittings and a Got-to-Show lines kit.
Gotta Show Products Home Page Featuring Hot Rod Plumbing
You'll need some interface to go from the flared steel to the NPT threads in the radiator. A brass adapter will prevent dissimilar metals corrosion. As long as the steel lines are mounted so that they can move around it'll be fine. AN fittings are definitely better, but millions of Ford cars went out of the factory with steel lines....it should work for you too!!
I didn't know the radiator was NPT..
There are no stupid questions right?
Chuck that looks great!!
Chuck, Is that a Superior Radiator from MT Clemens, MI ? Looks like it. Thats what old_dan and I have.
Nothing like a little Truck **** to get you going in the morning. Yes that is a Superior radiator and shroud from Mt Clemens
mirage5058
18
03-31-2015 02:31 AM
smashclash
12-06-2010 06:16 PM
dakotajeep
12-13-2008 08:52 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
07-19-2008 08:45 AM
broke33
03-21-2005 02:25 PM
