2003-2004 Ford F350 Truck 4WD Front Wheel Bearing & Hub Assembly for Models with Single Rear Wheels
VISIT US HERE FOR GREAT PRICES 2003-2004 Ford F350 Truck 4WD Front Wheel Bearing & Hub Assembly for Models with Single Rear Wheels (SRW) & 4 Wheel ABS Pair (Timken)
FREE SHIPPING IN THE LOWER 48 STATES!!!
TIMKEN WHEEL BEARING & HUB ASSEMBLIES: SP580205
These replacement hub & bearing assemblies are just what you need to get your vehicle in good working order again.
Specifications:
Brand New Timken Wheel Bearing & Hub Assemblies
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side) FRONT
Replaces dealer part numbers: 3C34-2B513-BC, 3C342B513BC
4 Bolt Flanges
Fit 8 Lug Wheels
Includes ABS sensors
Studs already installed
Direct replacements
Built to strict quality control standards
Fine thread studs
Fit 4WD (Four Wheel Drive) Models only
Fit models with SRW (Single Rear Wheels)
Fit models with AWAL (4 Wheel Anti-Lock Brakes)
Quality
You will not have a problem with our product. If you are comparing us to someone selling a brand name product remember brand names are only as good as the company selling them. Both Bizrate.com and The Better Business Bureau recognize 1A Auto as a trusted online seller. You will be pleased with what you find out about us.
You don't want to be delayed by a defective part. 1A Auto wheel hubs & bearings are all tested prior to shipping.
Fit Guaranteed
These hub & bearing sets will install just as your originals do. You can use your existing hardware.
Save time and money with direct fit hub bearing assemblies. No trips to the auto parts store or extra time trying to match up and press bearings.
Hub installation is a degree more difficult than changing a tire on most vehicles.
Value
Some shops and dealers charge more for parts and repairs when they think the customer doesn't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly part or repair bill.
Note: These parts are authentic Timken brand products that are supplied and packaged by Timken. In some cases, Timken will source parts from other high quality suppliers such as SKF and Koyo. These parts are subjected to the very same testing and quality standards as all Timken products.
2 Year Warranty
This item is backed by a 2 Year Manufacturers Warranty. In the event this item should fail during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
Part Brand: TIMKEN # SP580205
Specifications:
Comes as a PAIR
4 Bolt Flanges
Fit 8 Lug Wheels
Direct replacements
Fine thread studs
Quality
Fit Guaranteed
Value
2 Year Warranty
2003 Ford F350 Truck 4WD Front Wheel Bearing & Hub Assembly Pair for Models with 2 Wheel ABS & Singl
1Aauto
Vendor Specials, Discounts, Product Announcements & Group Buys
01-03-2014 02:44 PM
1Aauto
12-31-2013 01:46 PM
2005-2010 Ford F250 Truck Super Duty 4WD Front Wheel Bearing & Hub Assembly for Single Rear Wheels (
1Aauto
11-22-2013 01:53 PM
1997-1999 Ford F150 Truck 4WD Front Wheel Bearing & Hub Assembly for Models with Rear Wheel ABS Pair
1Aauto
05-21-2013 10:38 AM
1Aauto
05-21-2013 10:33 AM
